For the benefit of other readers this is the OP's program
// Define pin setup
#define motor_in1 7
#define motor_in2 8
#define motor_enA 9
int half_revolutions = 0;
// Set pin mode
pinMode(motor_enA, OUTPUT);
pinMode(motor_in1, OUTPUT);
pinMode(motor_in2, OUTPUT);
// Hallsensor connected to the interrupt pin (Pin 2 on Arduino Uno)
attachInterrupt(0, magnet_detect, RISING);
// Run full cycle to each position and back to 0
move_amount(1, 706, 255);
Serial.print(1);
move_amount(-1, 712, 255);
Serial.print(0);
move_amount(2, 710, 255);
Serial.print(2);
move_amount(-2, 715, 255);
Serial.print(0);
move_amount(3, 700, 255);
Serial.print(3);
move_amount(-3, 712, 255);
Serial.print(0);
move_amount(-1, 702, 255);
Serial.print(4);
move_amount(1,710, 255);
Serial.print(0);
move_amount(-2, 700, 255);
Serial.print(5);
move_amount(2, 715, 255);
Serial.print(0);
move_amount(-3,720, 255);
Serial.print(6);
move_amount(3, 715, 80);
Serial.print(0);
void magnet_detect() {
half_revolutions++;
void move_amount(int no_pos, int revolutions_per_pos, int carousel_speed) {
if (no_pos < 0) {
// Set rotation direction
digitalWrite(motor_in1, HIGH);
digitalWrite(motor_in2, LOW);
no_pos *= -1;
else {
digitalWrite(motor_in1, LOW);
digitalWrite(motor_in2, HIGH);
while (half_revolutions < (no_pos * (2 * revolutions_per_pos))) {
Serial.println(half_revolutions);
analogWrite(motor_enA, 180);
analogWrite(motor_enA, 0);
A few things occur to me ...
This line
should be
volatile int half_revolutions = 0;
because the variable is being updated in the ISR and the compiler might not know that.
And because it is a two-byte variable you should copy it into a working variable with interrupts suspended to avoid the risk of the value changing while you read it. Have a look at how it is done in the example code in this link
It may be that variable friction in the motor and gearbox is throwing your precision off - for example it may stop more quickly in one direction rather than the other.
Is your sensor on the motor shaft or on the output shaft of the gearbox
...R
