Hello everyone
I have caterpillar 12h grader have problem with gearbox so after I check it I discovered that the ecu is faulty then I decided to make controller for it using relays and diode and it worked perfectly.
But I think if I us arduino it will be better
I'm not too much good in programming I write one programme but didn't work so I need help .
The input signal is :
- Nutral
- Drive
- Revers
- gear one
-gear two
-gear three
The output signal :
Selonoid A
Selonoid b
Selonoid c
Selonoid e
Selonoid f
Selonoid g
Selonoid h
In this order:
Drive one= selonoid a and f and h will work together
Drive two = selonoid c and e and h
Drive three= selonoid c and g and h
Revers one = selonoid a and f and h
Reverse two = selonoid a and e and h
Revers three = selonoid a and g and h
Nutral = all the selonoid off.
