Hello everyone,
I’m a student at the Department of Electrical and Computer Engineering. Currently I’m working on my thesis based on an Arduino Uno R3 and I want to use the Geeetech Voice Recognition Module. I was having some problems, mainly with the sound part, but generally everything seemed to be working. I recoreded some commands and I focused on the coding. The problem is that today, when I connected the module and powered up the Arduino, I sent the 0xAA 0x00 command and I didn’t get any response. All the hardware parts seem fine, I checked it many times, as well as the baud rate etc. I also tried other commands, but still I don’t get any response at all… Any ideas?
This is known as troubleshooting. The problem that you describe can have a multitude of causes. You might begin with verifying voltages, not just by checking your wiring but by actually measuring supply voltage at the module and at the Arduino. If this fails to reveal anything, you might try swapping in a different Arduino or a different module, if you have one, to isolate the problem to one of these units. Much of your approach to diagnosing the problem will depend on what test equipment you have available to you.
S.
@arsenios
Your duplicate post has been deleted
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky “How to use this forum - please read.” post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
