Geiger counter with an arduino
Hello, i made a geiger counter long time a go using a kit bought from rhelectronics. Although it works just fine, i always wanted to use an arduino in order to get more information than just clicks and blinks. I found this project published at instructables (https://www.instructables.com/New-and-Improved-Geiger-Counter-Now-With-WiFi/), project witch i really enjoyed, however there is a lot of obstacles. First, i never truely programmed an arduino before had only used python in college (im a geologist) and secondly, the project above uses a different "electronic configuration" than the one i plan to use. Therefore, i'd like to ask for some help by answering some of my questions. 1) That project uses a NodeMCU instead of a arduino (in my case i plan to use an Arduino Mega), as far as i know the programming is the same although Prad's code uses ESP8266 libraries, could these work on an Arduino? If not, what libraries can i use in replace? 3) There is some fuctions i don't plan to use for instance, the wifi/internet option and the buzzer/LED indicator (my geiger already has both, although i would like to change the volume based of how radioactive is the object, but i think i can manage to do that). Should i delete them if i don't plan to use? Im asking this because they appear thoughout the code and im just i newbie and i fear i will delete something i should not. 4) we use the same GM (Geiger-Muller) tube, but with different electronics, i have 2 inputs (Vin and Vout) and 1 output (INT) in which i guess it carries out the pulses that translate into radioactive particles, but looking at his diagram/code i can't figure out what I/O port he uses to get the pulses to the ESP8266, can anybody tell me? Finally, i'd like to thank all of you who reached this far and i hope it wasn't too confuse and poorly written, i really wanted to understand the code, but right now i just want to finally finish this project that took me several years (health problems). Do you think i will be able to tackle this? I forgot to mention, but i also plan to use a TFT screen but 3,5'' instead
No. The ESP8266WiFi libraries are for the WiFi capability of the ESP8266 processor in the NodeMCU. The Arduino Mega doesn't have built-in WiFi. If you add a WiFi Shield to the Mega you could use WiFi but the libraries would be different.
Hello, sorry for the delay but i've been quite busy. I don't intend to use any of the wifi features, hence my question: can i leave them there or they will mess up with the code? Aside from that library, do i need to replace them with arduino compatible ones? (The list of libraries:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <EthernetClient.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WifiManager.h>
#include <EEPROM.h>
#include "SPI.h"
#include "Adafruit_GFX.h"
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include "Adafruit_ILI9341.h"
#include <XPT2046_Touchscreen.h>
#define CS_PIN D2
XPT2046_Touchscreen ts(CS_PIN);
#define TS_MINX 250
#define TS_MINY 200 // calibration points for touchscreen
#define TS_MAXX 3800
#define TS_MAXY 3750
#define TFT_DC D4
#define TFT_CS D8
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define DOSEBACKGROUND 0x0455
// WiFi variables
unsigned long currentUploadTime;
unsigned long previousUploadTime;
int passwordLength;
int SSIDLength;
int channelIDLength;
int writeAPILength;
char ssid[20];
char password[20];
char channelID[20]; // = "864288";
char channelAPIkey[20]; // = "37SAHQPEQ7FOBC20";
char server[] = "api.thingspeak.com";
int attempts; // number of connection attempts when device starts up in monitoring mode
WiFiClient client;
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
const int interruptPin = 5;
long count[61];
long fastCount[6]; // arrays to store running counts
long slowCount[181];
int i = 0;         // array elements
int j = 0;
int k = 0;
int page = 0;
long currentMillis;
long previousMillis;
unsigned long currentMicros;
unsigned long previousMicros;
unsigned long averageCount;
unsigned long currentCount;  // incremented by interrupt
unsigned long previousCount; // to activate buzzer and LED
unsigned long cumulativeCount;
float doseRate;
float totalDose;
char dose[5];
int doseLevel;               // determines home screen warning signs
int previousDoseLevel;
bool ledSwitch = 1;
bool buzzerSwitch = 1;
bool wasTouched;
int integrationMode = 0; // 0 = medium, 1 = fast, 2 == slow;
bool doseUnits = 0; // 0 = Sievert, 1 = Rem
unsigned int alarmThreshold = 5;
unsigned int conversionFactor = 175;
int x, y; // touch points
// Battery indicator variables
int batteryInput;
int batteryPercent;
int batteryMapped = 212;       // pixel location of battery icon
int batteryUpdateCounter = 29;
// EEPROM variables
const int saveUnits = 0;
const int saveAlertThreshold = 1; // Addresses for storing settings data in the EEPROM
const int saveCalibration = 2;
const int saveDeviceMode = 3;
const int saveLoggingMode = 4;
const int saveSSIDLen = 5;
const int savePWLen = 6;
const int saveIDLen = 7;
const int saveAPILen = 8;
// Data Logging variables
int addr = 200;                 // starting address for data logging
char jsonBuffer[14000] = "[";
char data[14500] = "{\"write_api_key\":\"";
unsigned long currentLogTime;
unsigned long previousLogTime;
// Timed Count Variables:
int interval = 5;
unsigned long intervalMillis;
unsigned long startMillis;
unsigned long elapsedTime;
int progress;
float cpm;
bool completed = 0;
int intervalSize; // stores how many digits are in the interval
// Logging variables
bool isLogging;
bool deviceMode;
// interrupt routine declaration
void ICACHE_RAM_ATTR isr();
unsigned int previousIntMicros;              // timers to limit count increment rate in the ISR
const unsigned char gammaBitmap [] PROGMEM = {
	0x30, 0x00, 0x78, 0x70, 0xe8, 0xe0, 0xc4, 0xe0, 0x84, 0xc0, 0x05, 0xc0, 0x05, 0x80, 0x07, 0x80,
	0x03, 0x00, 0x07, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x1e, 0x00, 0x1e, 0x00, 0x1e, 0x00, 0x3e, 0x00,
	0x1c, 0x00, 0x00, 0x00
const unsigned char betaBitmap [] PROGMEM = {
	0x00, 0xc0, 0x00, 0x03, 0xf0, 0x00, 0x07, 0x18, 0x00, 0x06, 0x18, 0x00, 0x0e, 0x18, 0x00, 0x0e,
	0x18, 0x00, 0x0e, 0xf8, 0x00, 0x0e, 0x1c, 0x00, 0x0e, 0x0c, 0x00, 0x0e, 0x0c, 0x00, 0x0e, 0x0c,
	0x00, 0x0e, 0x0c, 0x00, 0x0f, 0x1c, 0x00, 0x0f, 0xf8, 0x00, 0x0e, 0x00, 0x00, 0x0e, 0x00, 0x00,
	0x0c, 0x00, 0x00, 0x00, 0x00, 0x00
const unsigned char wifiBitmap [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x0f, 0xfe, 0x00, 0x3f, 0xff, 0x80, 0x78,
	0x03, 0xc0, 0xe0, 0x00, 0xe0, 0x47, 0xfc, 0x40, 0x0f, 0xfe, 0x00, 0x1c, 0x07, 0x00, 0x08, 0x02,
	0x00, 0x01, 0xf0, 0x00, 0x03, 0xf8, 0x00, 0x01, 0x10, 0x00, 0x00, 0x40, 0x00, 0x00, 0xe0, 0x00,
	0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
const unsigned char settingsBitmap[] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00,
    0x00, 0x01, 0xc0, 0x7f, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x7f, 0xe0, 0xfc, 0x00, 0x00,
    0x00, 0x07, 0xf9, 0xff, 0xf9, 0xfe, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00,
    0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00,
    0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00,
    0x00, 0x03, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00,
    0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x03, 0xff, 0xf0, 0x7f, 0xfc, 0x00, 0x00,
    0x00, 0x03, 0xff, 0xc0, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x1f, 0xff, 0x80, 0x1f, 0xff, 0x80, 0x00,
    0x00, 0xff, 0xff, 0x00, 0x0f, 0xff, 0xf0, 0x00, 0x01, 0xff, 0xff, 0x00, 0x07, 0xff, 0xf8, 0x00,
    0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00,
    0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x00, 0xff, 0xff, 0x00, 0x0f, 0xff, 0xf0, 0x00,
    0x00, 0x1f, 0xff, 0x80, 0x1f, 0xff, 0x80, 0x00, 0x00, 0x03, 0xff, 0xc0, 0x3f, 0xfc, 0x00, 0x00,
    0x00, 0x03, 0xff, 0xe0, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00,
    0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00,
    0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x07, 0xf9, 0xff, 0xf9, 0xfe, 0x00, 0x00,
    0x00, 0x03, 0xf0, 0x7f, 0xe0, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x7f, 0xe0, 0x38, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
const unsigned char buzzerOnBitmap[] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0c, 0x00,
    0x00, 0x00, 0x07, 0x80, 0x0e, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x1f, 0x80,
    0x07, 0x00, 0x00, 0x00, 0x3f, 0x80, 0xc7, 0x80, 0x00, 0x00, 0xff, 0x80, 0xe3, 0x80, 0x00, 0x01,
    0xff, 0x80, 0xf3, 0xc0, 0x00, 0x03, 0xff, 0x80, 0x71, 0xc0, 0x00, 0x07, 0xff, 0x8c, 0x79, 0xc0,
    0x3f, 0xff, 0xff, 0x9e, 0x38, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x38, 0xe0, 0x3f, 0xff, 0xff, 0x8e,
    0x3c, 0xe0, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0xe0, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x60, 0x3f, 0xff,
    0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70,
    0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87,
    0x1c, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x3c, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x38, 0xe0, 0x3f, 0xff,
    0xff, 0x9e, 0x38, 0xe0, 0x00, 0x07, 0xff, 0x8c, 0x79, 0xc0, 0x00, 0x03, 0xff, 0x80, 0x71, 0xc0,
    0x00, 0x00, 0xff, 0x80, 0xf1, 0xc0, 0x00, 0x00, 0x7f, 0x80, 0xe3, 0x80, 0x00, 0x00, 0x3f, 0x80,
    0xc7, 0x80, 0x00, 0x00, 0x1f, 0x80, 0x07, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0x00, 0x00, 0x00,
    0x07, 0x80, 0x0e, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char buzzerOffBitmap[] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80,
    0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00,
    0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x03, 0xff, 0x80, 0x00, 0x00, 0x00, 0x07, 0xff, 0x80, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x80,
    0x00, 0x00, 0x0f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x1f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x3f, 0xff,
    0xff, 0x8f, 0x00, 0x78, 0x7f, 0xff, 0xff, 0x8f, 0x80, 0xf8, 0x7f, 0xff, 0xff, 0x8f, 0xc1, 0xf8,
    0x7f, 0xff, 0xff, 0x87, 0xe3, 0xf0, 0x7f, 0xff, 0xff, 0x83, 0xf7, 0xe0, 0x7f, 0xff, 0xff, 0x81,
    0xff, 0xc0, 0x7f, 0xff, 0xff, 0x80, 0xff, 0x80, 0x7f, 0xff, 0xff, 0x80, 0x7f, 0x00, 0x7f, 0xff,
    0xff, 0x80, 0x7f, 0x00, 0x7f, 0xff, 0xff, 0x80, 0xff, 0x80, 0x7f, 0xff, 0xff, 0x81, 0xff, 0xc0,
    0x7f, 0xff, 0xff, 0x83, 0xf7, 0xe0, 0x7f, 0xff, 0xff, 0x87, 0xe3, 0xf0, 0x7f, 0xff, 0xff, 0x8f,
    0xc1, 0xf0, 0x7f, 0xff, 0xff, 0x8f, 0x80, 0xf8, 0x3f, 0xff, 0xff, 0x8f, 0x00, 0x70, 0x3f, 0xff,
    0xff, 0x84, 0x00, 0x20, 0x1f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x0f, 0xff, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x07, 0xff, 0x80, 0x00, 0x00, 0x00, 0x03, 0xff, 0x80, 0x00, 0x00, 0x00, 0x01, 0xff, 0x80,
    0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
    0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00,
    0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char ledOnBitmap[] PROGMEM = {
    0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
    0x00, 0x00, 0x00, 0x18, 0x07, 0x00, 0xc0, 0x00, 0x00, 0x1c, 0x07, 0x01, 0xc0, 0x00, 0x00, 0x1e,
    0x07, 0x03, 0xc0, 0x00, 0x00, 0x0e, 0x07, 0x03, 0x80, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00,
    0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x1e, 0x00, 0x1f, 0xc0, 0x03, 0xc0, 0x0f, 0x80, 0x7f, 0xf0, 0x0f, 0x80, 0x07, 0xc1,
    0xff, 0xfc, 0x1f, 0x00, 0x03, 0xc3, 0xe0, 0x3e, 0x1e, 0x00, 0x00, 0x07, 0xc0, 0x0f, 0x00, 0x00,
    0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03,
    0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x7f, 0x1c,
    0x00, 0x01, 0xc3, 0xf0, 0x7f, 0x1c, 0x00, 0x01, 0xc7, 0xf0, 0x3c, 0x0e, 0x00, 0x03, 0x81, 0xe0,
    0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0f, 0x00, 0x07,
    0x80, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0f, 0x00, 0x00, 0x01, 0xc3,
    0xc0, 0x1e, 0x1c, 0x00, 0x07, 0xc1, 0xc0, 0x1c, 0x1f, 0x00, 0x0f, 0x81, 0xe0, 0x3c, 0x0f, 0x80,
    0x1e, 0x00, 0xe0, 0x38, 0x03, 0xc0, 0x0c, 0x00, 0xe0, 0x38, 0x01, 0x80, 0x00, 0x00, 0xf0, 0x78,
    0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00,
    0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00,
    0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0,
    0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00};
const unsigned char ledOffBitmap[] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x01,
    0xff, 0xfc, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x3e, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x0f, 0x00, 0x00,
    0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x1c,
    0x00, 0x01, 0xc0, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00,
    0x80, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x03,
    0xc0, 0x1e, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x1c, 0x00, 0x00, 0x00, 0x01, 0xe0, 0x3c, 0x00, 0x00,
    0x00, 0x00, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x78,
const unsigned char backBitmap [] PROGMEM = {
    0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0,
    0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0,
    0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
void drawHomePage();              // page 0
void drawSettingsPage();          // page 1
void drawUnitsPage();             // page 2
void drawAlertPage();             // page 3
void drawCalibrationPage();       // page 4
void drawWifiPage();              // page 5
void drawTimedCountPage();        // page 6
void drawTimedCountRunningPage(int duration, int size); // page 7
void drawDeviceModePage();        // page 8
void drawFrame();
void drawBackButton();
void drawCancelButton();
void drawCloseButton();
void drawBlankDialogueBox();
long EEPROMReadlong(long address);
void EEPROMWritelong(int address, long value); // logging functions
void createJsonFile();
void clearLogs();
  Serial.begin(38400);
  ts.begin();
  ts.setRotation(2);
  tft.begin();
  tft.setRotation(2);
  tft.fillScreen(ILI9341_BLACK);
  pinMode(D0, OUTPUT); // buzzer switch
  pinMode(D3, OUTPUT); // LED
  digitalWrite(D3, LOW);
  digitalWrite(D0, LOW);
  EEPROM.begin(4096);   // initialize emulated EEPROM sector with 4 kb
  doseUnits = EEPROM.read(saveUnits);
  alarmThreshold = EEPROM.read(saveAlertThreshold);
  conversionFactor = EEPROM.read(saveCalibration);
  deviceMode = EEPROM.read(saveDeviceMode);
  isLogging = EEPROM.read(saveLoggingMode);
  addr = EEPROMReadlong(96);
  SSIDLength = EEPROM.read(saveSSIDLen);
  passwordLength = EEPROM.read(savePWLen);
  channelIDLength = EEPROM.read(saveIDLen);
  writeAPILength = EEPROM.read(saveAPILen);
  for (int i = 10; i < 10 + SSIDLength; i++)
    ssid[i - 10] = EEPROM.read(i);
  Serial.println(ssid);
  for (int j = 30; j < 30 + passwordLength; j++)
    password[j - 30] = EEPROM.read(j);
  Serial.println(password);
  for (int k = 50; k < 50 + channelIDLength; k++)
    channelID[k - 50] = EEPROM.read(k);
  Serial.println(channelID);
  for (int l = 70; l < 70 + writeAPILength; l++)
    channelAPIkey[l - 70] = EEPROM.read(l);
  Serial.println(channelAPIkey);
  attachInterrupt(interruptPin, isr, FALLING);
  drawHomePage();
  if (!deviceMode)
    WiFi.mode( WIFI_OFF );                // turn off wifi
    WiFi.forceSleepBegin();
    delay(1);
    WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
    tft.setTextSize(1);
    tft.setFont(&FreeSans9pt7b);
    tft.setTextColor(ILI9341_WHITE);
    tft.setCursor(38, 140);
    tft.println("Connecting to WiFi..");
    while ((WiFi.status() != WL_CONNECTED) && (attempts < 300))
      delay(100);
      attempts ++;
    if (attempts >= 300)
      deviceMode = 0;
      tft.setCursor(45, 200);
      tft.println("Failed to connect.");
      tft.setCursor(68, 200);
      tft.println("Connected!");
    drawHomePage();
  if (page == 0) // homepage
    currentMillis = millis();
    if (currentMillis - previousMillis >= 1000)
      batteryUpdateCounter ++;
      if (batteryUpdateCounter == 30){         // update battery level every 30 seconds. Prevents random fluctations of battery level.
        batteryInput = analogRead(A0);
        batteryInput = constrain(batteryInput, 590, 800);
        batteryPercent = map(batteryInput, 590, 800, 0, 100);
        batteryMapped = map(batteryPercent, 100, 0, 212, 233);
        tft.fillRect(212, 6, 22, 10, ILI9341_BLACK);
        if (batteryPercent < 10)
          tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_RED);
          tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_GREEN); // draws battery icon
        batteryUpdateCounter = 0;
        Serial.println(batteryInput);
        Serial.println(batteryPercent);
      count[i] = currentCount;
      i++;
      fastCount[j] = currentCount; // keep concurrent arrays of counts. Use only one depending on user choice
      j++;
      slowCount[k] = currentCount;
      k++;
      if (i == 61)
        i = 0;
      if (j == 6)
        j = 0;
      if (k == 181)
        k = 0;
      if (integrationMode == 2)
        averageCount = (currentCount - slowCount[k]) / 3;
      if (integrationMode == 1)
        averageCount = (currentCount - fastCount[j]) * 12;
      else if (integrationMode == 0)
        averageCount = currentCount - count[i]; // count[i] stores the value from 60 seconds ago
      averageCount = ((averageCount) / (1 - 0.00000333 * float(averageCount))); // accounts for dead time of the geiger tube. relevant at high count rates
      if (doseUnits == 0)
        doseRate = averageCount / float(conversionFactor);
        totalDose = cumulativeCount / (60 * float(conversionFactor));
      else if (doseUnits == 1)
        doseRate = averageCount / float(conversionFactor * 10.0);
        totalDose = cumulativeCount / (60 * float(conversionFactor * 10.0)); // 1 mRem == 10 uSv
      if (averageCount < conversionFactor/2) // 0.5 uSv/hr
        doseLevel = 0; // determines alert level displayed on homescreen
      else if (averageCount < alarmThreshold * conversionFactor)
        doseLevel = 1;
        doseLevel = 2;
      if (doseRate < 10.0)
        dtostrf(doseRate, 4, 2, dose); // display two digits after the decimal point if value is less than 10
      else if ((doseRate >= 10) && (doseRate < 100))
        dtostrf(doseRate, 4, 1, dose); // display one digit after decimal point when dose is greater than 10
      else if ((doseRate >= 100))
        dtostrf(doseRate, 4, 0, dose); // whole numbers only when dose is higher than 100
      else {
        dtostrf(doseRate, 4, 0, dose);  // covers the rare edge case where the dose rate is sometimes errorenously calculated to be negative
      tft.setFont();
      tft.setCursor(44, 52);
      tft.setTextSize(5);
      tft.setTextColor(ILI9341_WHITE, DOSEBACKGROUND);
      tft.println(dose); // display effective dose rate
      tft.setTextSize(1);
      tft.setFont();
      tft.setCursor(73, 122);
      tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
      tft.setTextSize(3);
      tft.println(averageCount); // Display CPM
      if (averageCount < 10)
        tft.fillRect(90, 120, 144, 25, ILI9341_BLACK); // erase numbers that may have been left from previous high readings
      else if (averageCount < 100)
        tft.fillRect(107, 120, 127, 25, ILI9341_BLACK);
      else if (averageCount < 1000)
        tft.fillRect(124, 120, 110, 25, ILI9341_BLACK);
      else if (averageCount < 10000)
        tft.fillRect(141, 120, 93, 25, ILI9341_BLACK);
      else if (averageCount < 100000)
        tft.fillRect(160, 120, 74, 25, ILI9341_BLACK);
      tft.setCursor(80, 192);
      tft.setTextSize(2);
      tft.setTextColor(ILI9341_WHITE, 0x630C);
      tft.println(cumulativeCount); // display total counts since reset
      tft.setCursor(80, 222);
      tft.println(totalDose); // display cumulative dose
      if (doseLevel != previousDoseLevel) // only update alert level if it changed. This prevents flicker
        if (doseLevel == 0)
          tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_WHITE);
          tft.fillRoundRect(3, 94, 234, 21, 3, 0x2DC6);
          tft.setCursor(15, 104);
          tft.setTextSize(1);
          tft.println("NORMAL BACKGROUND");
          previousDoseLevel = doseLevel;
        else if (doseLevel == 1)
          tft.fillRoundRect(3, 94, 234, 21, 3, 0xCE40);
          tft.setCursor(29, 104);
          tft.setTextSize(1);
          tft.println("ELEVATED ACTIVITY");
        else if (doseLevel == 2)
          tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_RED);
          tft.fillRoundRect(3, 94, 234, 21, 3, 0xB8A2);
          tft.setCursor(17, 104);
          tft.setTextSize(1);
          tft.println("HIGH RADIATION LEVEL");
      Serial.println(currentCount);
    // end of millis()-controlled block that runs once every second. The rest of the code on page 0 runs every loop
    if (currentCount > previousCount)
      if (ledSwitch)
        digitalWrite(D3, HIGH); // trigger buzzer and led if they are activated
      if (buzzerSwitch)
        digitalWrite(D0, HIGH);
      previousCount = currentCount;
      previousMicros = micros();
    currentMicros = micros();
    if (currentMicros - previousMicros >= 200)
      previousMicros = currentMicros;
    if (!ts.touched())
      wasTouched = 0;
    if (ts.touched() && !wasTouched) // A way of "debouncing" the touchscreen. Prevents multiple inputs from single touch
      wasTouched = 1;
      TS_Point p = ts.getPoint();
      x = map(p.x, TS_MINX, TS_MAXX, 240, 0); // get touch point and map to screen pixels
      y = map(p.y, TS_MINY, TS_MAXY, 320, 0);
      if ((x > 162 && x < 238) && (y > 259 && y < 318))
        integrationMode ++;
        if (integrationMode == 3)
        currentCount = 0;
        previousCount = 0;
        for (int a = 0; a < 61; a++) // reset counts when integretation speed is changed
          count[a] = 0;
        for (int b = 0; b < 6; b++)
          fastCount[b] = 0;
        for (int c = 0; c < 181; c++)
          slowCount[c] = 0;
        if (integrationMode == 0) // change button based on touch and previous state
          tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86);
          tft.setFont(&FreeSans12pt7b);
          tft.setTextSize(1);
          tft.setCursor(180, 283);
          tft.println("INT");
          tft.setCursor(177, 309);
          tft.println("60 s");
        else if (integrationMode == 1)
          tft.setTextSize(1);
          tft.println("INT");
          tft.setCursor(184, 309);
          tft.println("5 s");
        else if (integrationMode == 2)
          tft.setTextSize(1);
          tft.println("INT");
          tft.setCursor(169, 309);
          tft.println("180 s");
      else if ((x > 64 && x < 159) && (y > 259 && y < 318)) // timed count
        page = 6;
      else if ((x > 190 && x < 238) && (y > 151 && y < 202)) // toggle LED
        ledSwitch = !ledSwitch;
        if (ledSwitch)
          tft.fillRoundRect(190, 151, 46, 51, 3, 0x6269);
          tft.drawBitmap(190, 153, ledOnBitmap, 45, 45, ILI9341_WHITE);
          tft.drawBitmap(190, 153, ledOffBitmap, 45, 45, ILI9341_WHITE);
      else if ((x > 190 && x < 238) && (y > 205 && y < 256)) // toggle buzzer
        buzzerSwitch = !buzzerSwitch;
        if (buzzerSwitch)
          tft.fillRoundRect(190, 205, 46, 51, 3, 0x6269);
          tft.drawBitmap(190, 208, buzzerOnBitmap, 45, 45, ILI9341_WHITE);
          tft.drawBitmap(190, 208, buzzerOffBitmap, 45, 45, ILI9341_WHITE);
      else if ((x > 3 && x < 61) && (y > 259 && y < 316)) // settings button pressed
        page = 1;
        drawSettingsPage();
    if (isLogging)
      if(addr < 2100)
        currentLogTime = millis();
        if ((currentLogTime - previousLogTime) >= 600000)   // log every 10 minutes
          EEPROMWritelong(addr, averageCount);
          addr += 4;
          EEPROMWritelong(96, addr); // write current address number to an adress just before the logged data
          previousLogTime = currentLogTime;
          EEPROM.commit();
    if (deviceMode)    // deviceMode is 1 when in monitoring station mode. Uploads CPM to thingspeak every 5 minutes
      currentUploadTime = millis();
      if ((currentUploadTime - previousUploadTime) > 300000)
        previousUploadTime = currentUploadTime;
        if (client.connect(server, 80))
          String postStr = channelAPIkey;
          postStr += "&field2=";
          postStr += String(averageCount);
          postStr += "\r\n\r\n";
          char temp[50] = "X-THINGSPEAKAPIKEY:";
          strcat(temp, channelAPIkey);
          strcat(temp, "\n");
          client.print("POST /update HTTP/1.1\n");
          client.print("Host: api.thingspeak.com\n");
          client.print("Connection: close\n");
          client.print(temp);
          client.print("Content-Type: application/x-www-form-urlencoded\n");
          client.print("Content-Length: ");
          client.print(postStr.length());
          client.print("\n\n");
          client.print(postStr);
          Serial.println(postStr);
        client.stop();
  else if (page == 1) // settings page. all display elements are drawn when drawSettingsPage() is called
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
      if ((x > 4 && x < 62) && (y > 271 && y < 315)) // back button. draw homepage, reset counts and go back
        currentCount = 0;
        previousCount = 0;
          count[a] = 0; // counts need to be reset to prevent errorenous readings
          fastCount[b] = 0;
          slowCount[c] = 0;
        page = 0;
        drawHomePage();
      else if ((x > 3 && x < 234) && (y > 64 && y < 108))
        page = 2;
        drawUnitsPage();
      else if ((x > 3 && x < 234) && (y > 114 && y < 158))
        page = 3;
        drawAlertPage();
      else if ((x > 3 && x < 234) && (y > 164 && y < 208))
        page = 4;
      else if ((x > 3 && x < 234) && (y > 214 && y < 268))
        page = 5;
        drawWifiPage();
  else if (page == 2) // units page
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        if (EEPROM.read(saveUnits) != doseUnits) // check current EEPROM value and only write if new value is different
          EEPROM.write(saveUnits, doseUnits); // save current units to EEPROM during exit. This will be retrieved at startup
          EEPROM.commit();
        drawSettingsPage();
      else if ((x > 4 && x < 234) && (y > 70 && y < 120))
        doseUnits = 0;
        tft.fillRoundRect(4, 71, 232, 48, 4, 0x2A86);
        tft.setCursor(30, 103);
        tft.println("Sieverts (uSv/hr)");
        tft.fillRoundRect(4, 128, 232, 48, 4, ILI9341_BLACK);
        tft.setCursor(47, 160);
        tft.println("Rems (mR/hr)");
      else if ((x > 4 && x < 234) && (y > 127 && y < 177))
        doseUnits = 1;
        tft.fillRoundRect(4, 71, 232, 48, 4, ILI9341_BLACK);
        tft.fillRoundRect(4, 128, 232, 48, 4, 0x2A86);
  else if (page == 3)        // alert thresold page
    tft.setFont();
    tft.setTextSize(3);
    tft.setCursor(151, 146);
    tft.println(alarmThreshold);
    if (alarmThreshold < 10)
      tft.fillRect(169, 146, 22, 22, ILI9341_BLACK);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        if (EEPROM.read(saveAlertThreshold) != alarmThreshold)
          EEPROM.write(saveAlertThreshold, alarmThreshold);
          EEPROM.commit(); // save to EEPROM to be retrieved at startup
        drawSettingsPage();
      else if ((x > 130 && x < 190) && (y > 70 && y < 120))
        alarmThreshold++;
        if (alarmThreshold > 100)
          alarmThreshold = 100;
      else if ((x > 130 && x < 190) && (y > 185 && y < 245))
        alarmThreshold--;
        if (alarmThreshold <= 2)
          alarmThreshold = 2;
  else if (page == 4)     // calibration page
    tft.setFont();
    tft.setTextSize(3);
    tft.setCursor(161, 146);
    tft.println(conversionFactor);
    if (conversionFactor < 100)
      tft.fillRect(197, 146, 22, 22, ILI9341_BLACK);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        if (EEPROM.read(saveCalibration) != conversionFactor)
          EEPROM.write(saveCalibration, conversionFactor);
          EEPROM.commit();
        drawSettingsPage();
      else if ((x > 160 && x < 220) && (y > 70 && y < 120))
        conversionFactor++;
      else if ((x > 160 && x < 220) && (y > 185 && y < 245))
        conversionFactor--;
        if (conversionFactor <= 1)
          conversionFactor = 1;
  else if (page == 5)  // Wifi page
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        if (EEPROM.read(saveLoggingMode) != isLogging) // check current EEPROM value and only write if new value is different
          EEPROM.write(saveLoggingMode, isLogging);
          EEPROM.commit();
        drawSettingsPage();
      else if ((x > 3 && x < 237) && (y > 64 && y < 108))  // wifi setup button
        tft.setTextSize(1);
        tft.fillRoundRect(10, 30, 220, 260, 6, ILI9341_BLACK);
        tft.drawRoundRect(10, 30, 220, 260, 6, ILI9341_WHITE);
        tft.setCursor(50, 50);
        tft.println("AP SETUP MODE");
        tft.drawFastHLine(50, 53, 145, ILI9341_WHITE);
        tft.setCursor(20, 80);
        tft.println("With any WiFi capable");
        tft.setCursor(20, 100);
        tft.println("device, connect to");
        tft.setCursor(20, 120);
        tft.println("network \"GC20\" and ");
        tft.setCursor(20, 140);
        tft.println("browse to 192.168.4.1");
        tft.setCursor(20, 160);
        tft.println("Enter credentials");
        tft.setCursor(20, 180);
        tft.println("of your WiFi network");
        tft.setCursor(20, 200);
        tft.println("and the Channel ID and");
        tft.setCursor(20, 220);
        tft.println("write API key of your");
        tft.setCursor(20, 240);
        tft.println("ThingSpeak channel");
        delay(100);
        WiFiManager wifiManager;
        char channelIDSt[20];
        char writeAPISt[20];
        WiFiManagerParameter channel_id("0", "Channel ID", channelIDSt, 20); // create custom parameters for setup
        WiFiManagerParameter write_api("1", "Write API", writeAPISt, 20);
        wifiManager.addParameter(&channel_id);
        wifiManager.addParameter(&write_api);
        wifiManager.startConfigPortal("GC20");            // put the esp in AP mode for wifi setup, create a network with name "GC20"
        strcpy(channelIDSt, channel_id.getValue());
        strcpy(writeAPISt, write_api.getValue());
        size_t idLen = String(channelIDSt).length();
        size_t apiLen = String(writeAPISt).length();
        char channelInit = EEPROM.read(4001);  // first character of channelID is stored in EEPROM address 4001
        char apiKeyInit = EEPROM.read(4002);   // Only overwrite channelIDSt and writeAPISt if new value of the first character is different from what was saved.
        if (channelInit != channelIDSt[0])
          for (unsigned int a = 50; a < 50 + idLen; a++)
            EEPROM.write((a), channelIDSt[a - 50]);
          EEPROM.write(saveIDLen, idLen);
        if(apiKeyInit != writeAPISt[0])
          for (unsigned int b = 70; b < 70 + apiLen; b++)
            EEPROM.write((b), writeAPISt[b - 70]);
          EEPROM.write(saveAPILen, apiLen);
        String ssidString = WiFi.SSID();      // retrieve ssid and password form the WifiManager library
        String passwordString = WiFi.psk();
        size_t ssidLen = ssidString.length();
        size_t passLen = passwordString.length();
        Serial.println(ssidLen);
        Serial.println(passLen);
        char ssidChar[20];
        char passwordChar[20];
        ssidString.toCharArray(ssidChar, ssidLen + 1);
        passwordString.toCharArray(passwordChar, passLen + 1);
        for (unsigned int a = 10; a < 10 + ssidLen; a++)
          EEPROM.write((a), ssidChar[a - 10]);             // save ssid and ssid length to EEPROM
        EEPROM.write(saveSSIDLen, ssidLen);
        for (unsigned int b = 30; b < 30 + passLen; b++)
          EEPROM.write((b), passwordChar[b - 30]);          // save password and password length to EEPROM
        EEPROM.write(savePWLen, passLen);
        EEPROM.write(4001, channelIDSt[0]);                 // save first characters of channel ID and api key to EEPROM
        EEPROM.write(4002, writeAPISt[0]);
        EEPROM.commit();
        tft.setCursor(16, 265);
        tft.println("Settings saved. Restarting");
        ESP.reset();
      else if ((x > 3 && x < 237) && (y > 162 && y < 206)) // upload data
        tft.setCursor(38, 100);
        tft.println("Connecting to Wifi..");
        delay(100);
        while (WiFi.status() != WL_CONNECTED) {    // Wait for the Wi-Fi to connect
          delay(100);
        tft.setCursor(36, 160);
        tft.println("Creating JSON file..");
        createJsonFile();                         // reads logged data from EEPROM and creates a json file
        Serial.println(jsonBuffer);
        tft.setCursor(70, 220);
        tft.println("Uploading..");
        char secondHalf[50] = "\",\"updates\":";
        strcat(data, channelAPIkey);
        strcat(data, secondHalf);
        strcat(data,jsonBuffer);                // concatenate strings together and store in array named data
        strcat(data,"}");
        Serial.println(data);
        client.stop();
        String data_length = String(strlen(data)+1);
        if (client.connect(server, 80)) {          // post data to thingspeak
          char temp1[100] = "POST /channels/";
          char temp2[30] = "/bulk_update.json HTTP/1.1";
          strcat(temp1, channelID);
          strcat(temp1, temp2);
          client.println(temp1);
          client.println("Host: api.thingspeak.com");
          client.println("User-Agent: mw.doc.bulk-update (Arduino ESP8266)");
          client.println("Connection: close");
          client.println("Content-Type: application/json");
          client.println("Content-Length: "+data_length);
          client.println();
          client.println(data);
          client.stop();
          WiFi.disconnect();
          delay(1);
          clearLogs();                 // erase logs and re-initialize the json buffer
          tft.setCursor(43, 260);
          tft.println("Resetting Device..");
          ESP.reset();
          tft.setCursor(50, 260);
          tft.println("Failed to upload");
          ESP.reset();
      else if ((x > 3 && x < 237) && (y > 114 && y < 158)) // logging
        isLogging = !isLogging;
        if (isLogging)
          tft.fillRoundRect(3, 114, 234, 44, 4, 0x3B8F);
          tft.drawRoundRect(3, 114, 234, 44, 4, WHITE);
          tft.setCursor(38, 145);
          tft.println("LOGGING ON");
          tft.fillRoundRect(3, 114, 234, 44, 4, 0xB9C7);
          tft.setCursor(33, 145);
          tft.println("LOGGING OFF");
      else if ((x > 3 && x < 237) && (y > 214 && y < 258))  // device mode
        page = 8;
  else if (page == 6) // timed count setup page
    if (interval < 10)
      intervalSize = 1;
    else if (interval < 100)
      intervalSize = 2;
      intervalSize = 3;
    tft.setFont();
    tft.setTextSize(3);
    tft.setCursor((185 - (intervalSize - 1) * 11), 146);
    tft.println(interval);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
        for (int a = 0; a < 60; a++)
        for (int b = 0; b < 5; b++)
          fastCount[b] = 0;
        for (int c = 0; c < 180; c++)
          slowCount[c] = 0;
      else if ((x > 145 && x < 235) && (y > 271 && y < 315))
        page = 7;
        drawTimedCountRunningPage(interval, intervalSize);
        interval += 5;
        if (interval >= 995)
          interval = 995;
        tft.fillRect(160, 130, 70, 40, ILI9341_BLACK);
        interval -= 5;
        if (interval <= 5)
          interval = 5;
  else if (page == 7) // timed count running page
    elapsedTime = millis() - startMillis;
    if(elapsedTime < intervalMillis)
      if((millis() - previousMillis) >= 1000)
        previousMillis = millis();
        tft.setFont();
        tft.setTextSize(3);
        tft.setCursor(101, 181);
        tft.println(currentCount);
        cpm = float(currentCount) / float((1 + elapsedTime) / 60000.0);
        tft.setCursor(101, 226);
        tft.println(cpm);
        if(cpm < 10)
          tft.fillRect(170, 225, 50, 40, ILI9341_BLACK);
        else if(cpm < 100)
          tft.fillRect(190, 225, 35, 40, ILI9341_BLACK);
        else if(cpm < 1000)
          tft.fillRect(209, 225, 18, 40, ILI9341_BLACK);
      progress = map(elapsedTime, 0, intervalMillis, 0, 217);
      tft.fillRect(12, 105, progress, 16, 0x25A6);
      if (completed == 0)
        drawCloseButton();
        completed = 1;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
      if ((x > 70 && x < 170) && (y > 271 && y < 315))
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
  else if (page == 8)          // device mode selection page
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 5;
        if (EEPROM.read(saveDeviceMode) != deviceMode) // check current EEPROM value and only write if new value is different
          EEPROM.write(saveDeviceMode, deviceMode);
          EEPROM.commit();
        drawWifiPage();
        deviceMode = 0;
        tft.setCursor(13, 103);
        tft.println("GEIGER COUNTER");
        tft.setCursor(30, 160);
        tft.println("MON. STATION");
        deviceMode = 1;
void drawHomePage()
  tft.fillRect(1, 21, 237, 298, ILI9341_BLACK);
  tft.drawRoundRect(210, 4, 26, 14, 3, ILI9341_WHITE);
  tft.drawLine(209, 8, 209, 13, ILI9341_WHITE); // Battery symbol
  tft.drawLine(208, 8, 208, 13, ILI9341_WHITE);
  tft.setTextSize(1);
  tft.setTextColor(ILI9341_CYAN);
  tft.setCursor(2, 16);
  tft.println("GC-20");
  tft.setFont();
  tft.setTextSize(2);
  tft.setCursor(118, 4);
  tft.println("+");
  tft.setTextSize(1);
  tft.drawBitmap(103, 2, betaBitmap, 18, 18, ILI9341_WHITE);
  tft.drawBitmap(128, 2, gammaBitmap, 12, 18, ILI9341_WHITE);
  tft.drawLine(1, 20, 238, 20, ILI9341_WHITE);
  tft.fillRoundRect(3, 23, 234, 69, 3, DOSEBACKGROUND);
  tft.setCursor(16, 40);
  tft.println("EFFECTIVE DOSE RATE:");
  tft.setCursor(165, 85);
  if (doseUnits == 0)
    tft.println("uSv/hr");
    tft.println("mR/hr");
  tft.setCursor(15, 110);
  tft.setTextSize(1);
  tft.setCursor(7, 141);
  tft.println("CPM:");
  tft.drawRoundRect(3, 117, 234, 32, 3, DOSEBACKGROUND);
  tft.fillRoundRect(3, 151, 185, 105, 4, 0x630C);
  tft.setCursor(9, 171);
  tft.println("CUMULATIVE DOSE");
  tft.setCursor(7, 205);
  tft.println("Counts:");
  if (doseUnits == 0)
    tft.setCursor(34, 235);
    tft.println("uSv:");
    tft.setCursor(37, 235);
    tft.println("mR:");
  tft.fillRoundRect(3, 259, 58, 57, 3, 0x3B8F);
  tft.drawBitmap(1, 257, settingsBitmap, 60, 60, ILI9341_WHITE);
  tft.fillRoundRect(64, 259, 95, 57, 3, 0x6269);
  tft.setTextSize(1);
  tft.setCursor(74, 284);
  tft.println("TIMED");
  tft.setCursor(70, 309);
  tft.println("COUNT");
    tft.println("INT");
    tft.println("INT");
    tft.println("5 s");
    tft.println("INT");
  if (ledSwitch)
  else if (!ledSwitch)
  if (buzzerSwitch)
  else if (!buzzerSwitch)
  if (isLogging)
    tft.setCursor(175, 16);
    tft.println("L");
    tft.fillRect(175, 2, 18, 18, ILI9341_BLACK);
  if (deviceMode)
    tft.drawBitmap(188, 1, wifiBitmap, 19, 19, ILI9341_WHITE);
    tft.fillRect(188, 1, 19, 19, ILI9341_BLACK);
  drawFrame();
  tft.fillRoundRect(3, 23, 234, 35, 3, 0x3B8F);
  tft.setCursor(57, 48);
  tft.println("SETTINGS");
  tft.drawFastHLine(59, 51, 117, WHITE);
  tft.fillRoundRect(3, 64, 234, 44, 4, 0x2A86);
  tft.drawRoundRect(3, 64, 234, 44, 4, WHITE);
  tft.setCursor(44, 94);
  tft.println("DOSE UNITS");
  tft.fillRoundRect(3, 114, 234, 44, 4, 0x2A86);
  tft.setCursor(5, 145);
  tft.println("ALERT THRESHOLD");
  tft.fillRoundRect(3, 164, 234, 44, 4, 0x2A86);
  tft.drawRoundRect(3, 164, 234, 44, 4, WHITE);
  tft.setCursor(37, 194);
  tft.println("CALIBRATION");
  tft.fillRoundRect(3, 214, 234, 44, 4, 0x2A86);
  tft.drawRoundRect(3, 214, 234, 44, 4, WHITE);
  tft.setCursor(8, 244);
  tft.println("LOGGING AND WIFI");
  drawBackButton();
  drawFrame();
  tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F);
  tft.setCursor(84, 51);
  tft.println("UNITS");
  tft.drawFastHLine(86, 55, 71, WHITE);
  drawBackButton();
  tft.drawRoundRect(3, 70, 234, 50, 4, WHITE);
  if (doseUnits == 0)
  tft.drawRoundRect(3, 127, 234, 50, 4, WHITE);
  if (doseUnits == 1)
  drawFrame();
  tft.setCursor(4, 51);
  tft.drawFastHLine(5, 55, 229, WHITE);
  drawBackButton();
  tft.setCursor(30, 164);
  tft.println("uSv/hr:");
  tft.drawRoundRect(130, 70, 60, 60, 4, ILI9341_WHITE);
  tft.fillRoundRect(131, 71, 58, 58, 4, 0x2A86);
  tft.drawRoundRect(130, 185, 60, 60, 4, ILI9341_WHITE);
  tft.fillRoundRect(131, 186, 58, 58, 4, 0x2A86);
  tft.setCursor(140, 113);
  tft.setTextSize(3);
  tft.println("+");
  tft.setCursor(148, 232);
  tft.println("-");
  tft.setTextSize(1);
  drawFrame();
  tft.setCursor(47, 51);
  tft.println("CALIBRATE");
  tft.drawFastHLine(48, 55, 133, WHITE);
  drawBackButton();
  tft.setCursor(8, 154);
  tft.println("Conversion Factor");
  tft.setCursor(8, 174);
  tft.println("(CPM per uSv/hr)");
  tft.drawRoundRect(160, 70, 60, 60, 4, ILI9341_WHITE);
  tft.fillRoundRect(161, 71, 58, 58, 4, 0x2A86);
  tft.drawRoundRect(160, 185, 60, 60, 4, ILI9341_WHITE);
  tft.fillRoundRect(161, 186, 58, 58, 4, 0x2A86);
  tft.setCursor(170, 113);
  tft.setTextSize(3);
  tft.println("+");
  tft.setCursor(178, 232);
  tft.println("-");
  tft.setTextSize(1);
void drawWifiPage()
  drawFrame();
  drawBackButton();
  tft.setCursor(7, 48);
  tft.drawFastHLine(8, 51, 222, WHITE);
  tft.setCursor(48, 94);
  tft.println("WIFI SETUP");
  if (isLogging)
  tft.setCursor(31, 194);
  tft.println("UPLOAD DATA");
  tft.setCursor(35, 244);
  tft.println("DEVICE MODE");
  if (addr > 2000)
    tft.setCursor(80, 297);
    tft.println("Log memory full");
  drawFrame();
  drawBackButton();
  tft.fillRoundRect(145, 271, 92, 45, 3, 0x3B8F);
  tft.drawRoundRect(145, 271, 92, 45, 3, ILI9341_WHITE);
  tft.setCursor(149, 302);
  tft.println("BEGIN!");
  tft.setCursor(34, 51);
  tft.println("TIMED COUNT");
  tft.drawFastHLine(35, 55, 163, WHITE);
  tft.setCursor(5, 162);
  tft.println("Duration (minutes):");
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
  cpm = 0;
  progress = 0;
  drawFrame();
  drawCancelButton();
  tft.setTextSize(1);
  tft.drawRoundRect(3, 66, 234, 95, 4, ILI9341_WHITE);
  tft.drawRect(10, 103, 220, 20, ILI9341_WHITE);
  tft.drawRoundRect(3, 164, 234, 103, 4, ILI9341_WHITE);
  tft.setCursor(58, 90);
  tft.println("Progress:");
  tft.setCursor(13, 150);
  tft.println("Duration:");
  tft.setCursor(115, 150);
  tft.println(duration);
  tft.setCursor((135 + (size - 1)*15), 150);
  tft.println("min");
  tft.setCursor(15, 200);
  tft.setCursor(37, 245);
  currentCount = 0;
  startMillis = millis();
  intervalMillis = duration * 60000;
  completed = 0;
  drawFrame();
  tft.drawFastHLine(35, 57, 160, WHITE);
  drawBackButton();
  if (deviceMode == 0)
  if (deviceMode == 1)
  tft.println("Press Back button and");
  tft.println("reset device for changes");
  tft.println("to take effect");
void isr() // interrupt service routine
  if ((micros() - 200) > previousIntMicros){
    currentCount++;
    cumulativeCount++;
  previousIntMicros = micros();
void drawBackButton(){
  tft.fillRoundRect(4, 271, 62, 45, 3, 0x3B8F);
  tft.drawRoundRect(4, 271, 62, 45, 3, ILI9341_WHITE);
  tft.drawBitmap(4, 271, backBitmap, 62, 45, ILI9341_WHITE);
void drawFrame(){
  tft.fillRect(2, 21, 236, 298, ILI9341_BLACK);
  tft.setTextSize(1);
  tft.setFont();
  tft.setTextSize(2);
  tft.println("+");
  tft.setTextSize(1);
  if (isLogging)
    tft.println("L");
  if (deviceMode)
    tft.drawBitmap(188, 1, wifiBitmap, 18, 18, ILI9341_WHITE);
  tft.fillRoundRect(70, 271, 100, 45, 3, 0xB9C7);
  tft.drawRoundRect(70, 271, 100, 45, 3, ILI9341_WHITE);
  tft.setCursor(72, 302);
  tft.println("CANCEL");
  tft.fillRoundRect(70, 271, 100, 45, 3, 0x3B8F);
  tft.setTextSize(1);
  tft.setCursor(79, 302);
  tft.println("CLOSE");
long EEPROMReadlong(long address) {
  long four = EEPROM.read(address);
  long three = EEPROM.read(address + 1);
  long two = EEPROM.read(address + 2);
  long one = EEPROM.read(address + 3);
  return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
void EEPROMWritelong(int address, long value) {
  byte four = (value & 0xFF);
  byte three = ((value >> 8) & 0xFF);
  byte two = ((value >> 16) & 0xFF);
  byte one = ((value >> 24) & 0xFF);
  EEPROM.write(address, four);
  EEPROM.write(address + 1, three);
  EEPROM.write(address + 2, two);
  EEPROM.write(address + 3, one);
  Serial.println(addr);
  for (int i = 100; i < addr; i += 4)
    int count = EEPROMReadlong(i);
    int deltaT = 600;
    strcat(jsonBuffer,"{\"delta_t\":");
    size_t lengthT = String(deltaT).length();
    char temp[10];
    String(deltaT).toCharArray(temp,lengthT + 1);
    strcat(jsonBuffer,temp);
    strcat(jsonBuffer,",");
    strcat(jsonBuffer, "\"field1\":");
    lengthT = String(count).length();
    String(count).toCharArray(temp, lengthT + 1);
    strcat(jsonBuffer,"},");
  size_t len = strlen(jsonBuffer);
  jsonBuffer[len-1] = ']';
  tft.setTextSize(1);
  tft.fillRoundRect(20, 50, 200, 220, 6, ILI9341_BLACK);
  tft.drawRoundRect(20, 50, 200, 220, 6, ILI9341_WHITE);
void clearLogs()
  for (int j = 100; j < 4000; j ++)
    EEPROMWritelong(j, 0);
  for (int k = 1; k < 1000; k++) // keep the first character in jsonBuffer: "["
    jsonBuffer[k] = 0;
  addr = 100;
  EEPROM.write(saveLoggingMode, 0);
  EEPROM.commit();
  isLogging = 0;
Also, i still can't figure out what arduino input pin is the GM tube connected, does anyone know?
Thank you all!
You will probably get a ton of compile errors trying to use an ESP8266 library on an Arduino MEGA.
I recommend that you start by removing the #include lines for all of the WiFi-related libraries:
You might as well remove the section marked "WiFi variables" too:
// WiFi variables
int passwordLength;
int SSIDLength;
int writeAPILength;
char ssid[20];
char password[20];
WiFiClient client;
Then try to compile your sketch. You will get a LOT of errors. Look for any lines that are obviously related to WiFi and delete them. Repeat until all the errors are gone. With luck your sketch till work without the WiFi features.
Start with something in the AVR line of uC's.... maybe:
Geiger Counter with Arduino Uno - Arduino Project Hub
The Mega will run the same libs as UNO and you have plenty of SRAM and flash for LCD, etc.
Just to see how hard it might be, here is the sketch with all the ESP8266 parts commented out. It compiles without error or warning for Arduino MEGA. You can delete the commented lines if you want a neater appearance.
Warning: The 'int' type is 16-bits on an Arduino MEGA but 32-bits on an ESP8266. You may find places where you have to change 'int' or 'unsigned' to 'long' or 'unsigned long'.
//#include <ESP8266WiFi.h>
//#include <EthernetClient.h>
//#include <DNSServer.h>
//#include <ESP8266WebServer.h>
//#include <WifiManager.h>
#include <EEPROM.h>
#include "SPI.h"
// Map ESP8266 pin names to rduino pins
const byte D0 = 2;
const byte D1 = 3;
const byte D2 = 4;
const byte D3 = 5;
const byte D4 = 6;
const byte D5 = 7;
const byte D6 = 8;
const byte D7 = 9;
const byte D8 = 10;
// WiFi variables
//unsigned long currentUploadTime;
//unsigned long previousUploadTime;
//int passwordLength;
//int SSIDLength;
//int channelIDLength;
//int writeAPILength;
//char ssid[20];
//char password[20];
//char channelID[20]; // = "864288";
//char channelAPIkey[20]; // = "37SAHQPEQ7FOBC20";
//char server[] = "api.thingspeak.com";
//int attempts; // number of connection attempts when device starts up in monitoring mode
//WiFiClient client;
#define CS_PIN D2
#define TS_MINX 250
#define TFT_DC D4
#define TFT_CS D8
#define BLUE 0x001F
#define RED 0xF800
#define CYAN 0x07FF
long count[61];
int j = 0;
int k = 0;
int page = 0;
long currentMillis;
float doseRate;
float totalDose;
char dose[5];
bool ledSwitch = 1;
bool wasTouched;
int batteryInput;
int batteryPercent;
// EEPROM variables
int interval = 5;
int progress;
float cpm;
bool completed = 0;
bool isLogging;
bool deviceMode;
// void ICACHE_RAM_ATTR isr();  // ESP8266-style
void isr();
void drawFrame();
void clearLogs();
  ts.begin();
  ts.setRotation(2);
  tft.begin();
  tft.setRotation(2);
//  EEPROM.begin(4096);   // initialize ESP8266 emulated EEPROM sector with 4 kb
//  SSIDLength = EEPROM.read(saveSSIDLen);
//  passwordLength = EEPROM.read(savePWLen);
//  channelIDLength = EEPROM.read(saveIDLen);
//  writeAPILength = EEPROM.read(saveAPILen);
//  for (int i = 10; i < 10 + SSIDLength; i++)
//    ssid[i - 10] = EEPROM.read(i);
//  Serial.println(ssid);
//  for (int j = 30; j < 30 + passwordLength; j++)
//    password[j - 30] = EEPROM.read(j);
//  Serial.println(password);
//  for (int k = 50; k < 50 + channelIDLength; k++)
//    channelID[k - 50] = EEPROM.read(k);
//  Serial.println(channelID);
//  for (int l = 70; l < 70 + writeAPILength; l++)
//    channelAPIkey[l - 70] = EEPROM.read(l);
//  Serial.println(channelAPIkey);
  drawHomePage();
//  if (!deviceMode)
//    WiFi.mode( WIFI_OFF );                // turn off wifi
//    WiFi.forceSleepBegin();
//    delay(1);
//  else
//    WiFi.mode(WIFI_STA);
//    WiFi.begin(ssid, password);
    tft.setTextSize(1);
//    while ((WiFi.status() != WL_CONNECTED) && (attempts < 300))
//      delay(100);
//      attempts ++;
//    if (attempts >= 300)
//      deviceMode = 0;
//      tft.setCursor(45, 200);
//      tft.println("Failed to connect.");
//      delay(1000);
//    else
//      tft.setCursor(68, 200);
//      tft.println("Connected!");
//      delay(1000);
    drawHomePage();
      i++;
      j++;
      k++;
      if (i == 61)
        i = 0;
      if (j == 6)
        j = 0;
      if (k == 181)
        k = 0;
      if (doseUnits == 0)
        doseLevel = 1;
        doseLevel = 2;
      else {
      tft.setFont();
      tft.setTextSize(5);
      tft.setTextSize(1);
      tft.setFont();
      tft.setTextSize(3);
      tft.setTextSize(2);
        if (doseLevel == 0)
          tft.setTextSize(1);
          tft.setTextSize(1);
          tft.setTextSize(1);
      if (ledSwitch)
      if (buzzerSwitch)
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        integrationMode ++;
        currentCount = 0;
        previousCount = 0;
          count[a] = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
          tft.setTextSize(1);
          tft.println("INT");
          tft.setTextSize(1);
          tft.println("INT");
          tft.println("5 s");
          tft.setTextSize(1);
          tft.println("INT");
        page = 6;
        if (ledSwitch)
        if (buzzerSwitch)
        page = 1;
        drawSettingsPage();
    if (isLogging)
      if(addr < 2100)
          addr += 4;
//          EEPROM.commit(); // ESP8266 style
//    if (deviceMode)    // deviceMode is 1 when in monitoring station mode. Uploads CPM to thingspeak every 5 minutes
//      currentUploadTime = millis();
//      if ((currentUploadTime - previousUploadTime) > 300000)
//        previousUploadTime = currentUploadTime;
//        if (client.connect(server, 80))
//          String postStr = channelAPIkey;
//          postStr += "&field2=";
//          postStr += String(averageCount);
//          postStr += "\r\n\r\n";
//          char temp[50] = "X-THINGSPEAKAPIKEY:";
//          strcat(temp, channelAPIkey);
//          strcat(temp, "\n");
//          client.print("POST /update HTTP/1.1\n");
//          client.print("Host: api.thingspeak.com\n");
//          client.print("Connection: close\n");
//          client.print(temp);
//          client.print("Content-Type: application/x-www-form-urlencoded\n");
//          client.print("Content-Length: ");
//          client.print(postStr.length());
//          client.print("\n\n");
//          client.print(postStr);
//          Serial.println(postStr);
//        client.stop();
//  else
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
        page = 0;
        drawHomePage();
        page = 2;
        drawUnitsPage();
        page = 3;
        drawAlertPage();
        page = 4;
        page = 5;
        drawWifiPage();
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        doseUnits = 0;
        doseUnits = 1;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
//          EEPROM.commit(); // ESP8266-style save to EEPROM to be retrieved at startup
        drawSettingsPage();
        alarmThreshold++;
        alarmThreshold--;
          alarmThreshold = 2;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        conversionFactor++;
        conversionFactor--;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        tft.setTextSize(1);
        delay(100);
//        WiFiManager wifiManager;
//        char channelIDSt[20];
//        char writeAPISt[20];
//        WiFiManagerParameter channel_id("0", "Channel ID", channelIDSt, 20); // create custom parameters for setup
//        WiFiManagerParameter write_api("1", "Write API", writeAPISt, 20);
//        wifiManager.addParameter(&channel_id);
//        wifiManager.addParameter(&write_api);
//        wifiManager.startConfigPortal("GC20");            // put the esp in AP mode for wifi setup, create a network with name "GC20"
//        strcpy(channelIDSt, channel_id.getValue());
//        strcpy(writeAPISt, write_api.getValue());
//        size_t idLen = String(channelIDSt).length();
//        size_t apiLen = String(writeAPISt).length();
//        char channelInit = EEPROM.read(4001);  // first character of channelID is stored in EEPROM address 4001
//        char apiKeyInit = EEPROM.read(4002);   // Only overwrite channelIDSt and writeAPISt if new value of the first character is different from what was saved.
//        if (channelInit != channelIDSt[0])
//          for (unsigned int a = 50; a < 50 + idLen; a++)
//            EEPROM.write((a), channelIDSt[a - 50]);
//          EEPROM.write(saveIDLen, idLen);
//        if(apiKeyInit != writeAPISt[0])
//          for (unsigned int b = 70; b < 70 + apiLen; b++)
//            EEPROM.write((b), writeAPISt[b - 70]);
//          EEPROM.write(saveAPILen, apiLen);
//        String ssidString = WiFi.SSID();      // retrieve ssid and password form the WifiManager library
//        String passwordString = WiFi.psk();
//        size_t ssidLen = ssidString.length();
//        size_t passLen = passwordString.length();
//        Serial.println(ssidLen);
//        Serial.println(passLen);
//        char ssidChar[20];
//        char passwordChar[20];
//        ssidString.toCharArray(ssidChar, ssidLen + 1);
//        passwordString.toCharArray(passwordChar, passLen + 1);
//        for (unsigned int a = 10; a < 10 + ssidLen; a++)
//          EEPROM.write((a), ssidChar[a - 10]);             // save ssid and ssid length to EEPROM
//        EEPROM.write(saveSSIDLen, ssidLen);
//        for (unsigned int b = 30; b < 30 + passLen; b++)
//          EEPROM.write((b), passwordChar[b - 30]);          // save password and password length to EEPROM
//        EEPROM.write(savePWLen, passLen);
//        EEPROM.write(4001, channelIDSt[0]);                 // save first characters of channel ID and api key to EEPROM
//        EEPROM.write(4002, writeAPISt[0]);
//        EEPROM.commit();
//        ESP.reset();
//        tft.setCursor(38, 100);
//        tft.println("Connecting to Wifi..");
//        delay(100);
//        while (WiFi.status() != WL_CONNECTED) {    // Wait for the Wi-Fi to connect
//          delay(100);
//        tft.setCursor(36, 160);
//        tft.println("Creating JSON file..");
//        createJsonFile();                         // reads logged data from EEPROM and creates a json file
//        Serial.println(jsonBuffer);
//        delay(1000);
//        tft.setCursor(70, 220);
//        tft.println("Uploading..");
//        delay(1000);
//        char secondHalf[50] = "\",\"updates\":";
//        strcat(data, channelAPIkey);
//        strcat(data, secondHalf);
//        strcat(data,jsonBuffer);                // concatenate strings together and store in array named data
//        strcat(data,"}");
//        Serial.println(data);
//        client.stop();
//        String data_length = String(strlen(data)+1);
//        if (client.connect(server, 80)) {          // post data to thingspeak
//          char temp1[100] = "POST /channels/";
//          char temp2[30] = "/bulk_update.json HTTP/1.1";
//          strcat(temp1, channelID);
//          strcat(temp1, temp2);
//          client.println(temp1);
//          client.println("Host: api.thingspeak.com");
//          client.println("User-Agent: mw.doc.bulk-update (Arduino ESP8266)");
//          client.println("Connection: close");
//          client.println("Content-Type: application/json");
//          client.println("Content-Length: "+data_length);
//          client.println();
//          client.println(data);
//          client.stop();
//          WiFi.disconnect();
//          delay(1);
//          ESP.reset();
//          ESP.reset();
        if (isLogging)
        page = 8;
    if (interval < 10)
      intervalSize = 1;
      intervalSize = 2;
      intervalSize = 3;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
        page = 7;
        interval += 5;
          interval = 995;
        interval -= 5;
        if (interval <= 5)
          interval = 5;
        tft.setFont();
        tft.setTextSize(3);
        tft.println(cpm);
        if(cpm < 10)
        else if(cpm < 100)
        else if(cpm < 1000)
      if (completed == 0)
        drawCloseButton();
        completed = 1;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 5;
//          EEPROM.commit();
        drawWifiPage();
        deviceMode = 0;
        deviceMode = 1;
void drawHomePage()
  tft.setTextSize(1);
  tft.setFont();
  tft.setTextSize(2);
  tft.println("+");
  tft.setTextSize(1);
  if (doseUnits == 0)
  tft.setTextSize(1);
  if (doseUnits == 0)
    tft.println("mR:");
  tft.setTextSize(1);
    tft.println("INT");
    tft.println("INT");
    tft.println("5 s");
    tft.println("INT");
  if (ledSwitch)
  if (buzzerSwitch)
  if (isLogging)
    tft.println("L");
  if (deviceMode)
  drawFrame();
  drawBackButton();
  drawFrame();
  drawBackButton();
  if (doseUnits == 0)
  if (doseUnits == 1)
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
void drawWifiPage()
  drawFrame();
  drawBackButton();
  if (isLogging)
  if (addr > 2000)
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
  cpm = 0;
  progress = 0;
  drawFrame();
  drawCancelButton();
  tft.setTextSize(1);
  tft.println("min");
  currentCount = 0;
  completed = 0;
  drawFrame();
  drawBackButton();
    currentCount++;
    cumulativeCount++;
void drawFrame(){
  tft.setTextSize(1);
  tft.setFont();
  tft.setTextSize(2);
  tft.println("+");
  tft.setTextSize(1);
  if (isLogging)
    tft.println("L");
  if (deviceMode)
  tft.setTextSize(1);
    int deltaT = 600;
    char temp[10];
  tft.setTextSize(1);
void clearLogs()
    jsonBuffer[k] = 0;
  addr = 100;
//  EEPROM.commit();
  isLogging = 0;
Hello! first and foremost, thank you both for repplying and helping me out, i thought i wouldn't get any help at all. John, that's a great idea and i will do that not only for the internet part but to other things aswell. Mrburnette, i've seen that project before although i prefer the one im trying to fiddle with. So, i will delete everything i deem unnecessary.
Hello all, I've been looking at the changes john has done. I deleted all lines you commented, but i noticed that there was some more about the wifi/internet mode thus, i tried to comment them although the code won't compile, i think they depend on a larger cycle which i cannot delete since there is some math that, to me, seems necessery for the whole program to work, can you give me your opinion? Also, i noticed you left some comments regarding the eeprom.write, but i can't understand what they mean. Can you explain it to me or point me to some bibliography? Also applies to the variable types you mention in your last repply, i've been digging through the internet about variables types and i found some information at adafruit website. From what i could understand, there are variables that are more optimized for some codes than others depending of the need, but i haven't understand the comparison you made between ArduinoMega/ESP8266 variables, could you point me to some bibliography aswel??
The last "iteration":
#include <EEPROM.h>
#include "SPI.h"
// Map ESP8266 pin names to arduino pins
const byte D0 = 2;
const byte D1 = 3;
const byte D2 = 4;
const byte D3 = 5;
const byte D4 = 6;
const byte D5 = 7;
const byte D6 = 8;
const byte D7 = 9;
const byte D8 = 10;
#define CS_PIN D2
#define TS_MINX 250
#define TFT_DC D4
#define TFT_CS D8
#define BLUE 0x001F
#define RED 0xF800
#define CYAN 0x07FF
long count[61];
int j = 0;
int k = 0;
int page = 0;
long currentMillis;
float doseRate;
float totalDose;
char dose[5];
bool ledSwitch = 1;
bool wasTouched;
int batteryInput;
int batteryPercent;
// EEPROM variables
int interval = 5;
int progress;
float cpm;
bool completed = 0;
bool isLogging;
bool deviceMode;
void isr();
void drawFrame();
void clearLogs();
  ts.begin();
  ts.setRotation(2);
  tft.begin();
  tft.setRotation(2);
  drawHomePage();
    tft.setTextSize(1);
    drawHomePage();
      i++;
      j++;
      k++;
      if (i == 61)
        i = 0;
      if (j == 6)
        j = 0;
      if (k == 181)
        k = 0;
      if (doseUnits == 0)
        doseLevel = 1;
        doseLevel = 2;
      else {
      tft.setFont();
      tft.setTextSize(5);
      tft.setTextSize(1);
      tft.setFont();
      tft.setTextSize(3);
      tft.setTextSize(2);
        if (doseLevel == 0)
          tft.setTextSize(1);
          tft.setTextSize(1);
          tft.setTextSize(1);
      if (ledSwitch)
      if (buzzerSwitch)
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        integrationMode ++;
        currentCount = 0;
        previousCount = 0;
          count[a] = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
          tft.setTextSize(1);
          tft.println("INT");
          tft.setTextSize(1);
          tft.println("INT");
          tft.println("5 s");
          tft.setTextSize(1);
          tft.println("INT");
        page = 6;
        if (ledSwitch)
        if (buzzerSwitch)
        page = 1;
        drawSettingsPage();
    if (isLogging)
      if(addr < 2100)
          addr += 4;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
        page = 0;
        drawHomePage();
        page = 2;
        drawUnitsPage();
        page = 3;
        drawAlertPage();
        page = 4;
        page = 5;
        drawWifiPage();
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        doseUnits = 0;
        doseUnits = 1;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        alarmThreshold++;
        alarmThreshold--;
          alarmThreshold = 2;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        conversionFactor++;
        conversionFactor--;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 1;
        drawSettingsPage();
        //tft.setFont(&FreeSans9pt7b);
        //tft.setTextSize(1);
        //tft.fillRoundRect(10, 30, 220, 260, 6, ILI9341_BLACK);
        //tft.drawRoundRect(10, 30, 220, 260, 6, ILI9341_WHITE);
        //tft.setCursor(50, 50);
        //tft.println("AP SETUP MODE");
        //tft.drawFastHLine(50, 53, 145, ILI9341_WHITE);
        //tft.setCursor(20, 80);
        //tft.println("With any WiFi capable");
        //tft.setCursor(20, 100);
        //tft.println("device, connect to");
        //tft.setCursor(20, 120);
        //tft.println("network \"GC20\" and ");
        //tft.setCursor(20, 140);
        //tft.println("browse to 192.168.4.1");
        //tft.setCursor(20, 160);
        //tft.println("Enter credentials");
        //tft.setCursor(20, 180);
        //tft.println("of your WiFi network");
        //tft.setCursor(20, 200);
        //tft.println("and the Channel ID and");
        //tft.setCursor(20, 220);
        //tft.println("write API key of your");
        //tft.setCursor(20, 240);
        //tft.println("ThingSpeak channel");
       // delay(100);//
        //tft.setCursor(16, 265);
        //tft.println("Settings saved. Restarting");
        //delay(1000);
//        ESP.reset();
     // else if ((x > 3 && x < 237) && (y > 162 && y < 206)) // upload data
        //drawBlankDialogueBox();
          //clearLogs();                 // erase logs and re-initialize the json buffer
          //tft.setCursor(43, 260);
          //tft.println("Resetting Device..");
          //delay(1000);
//          ESP.reset();
        //else
         // tft.setCursor(50, 260);
          //tft.println("Failed to upload");
          //delay(1000);
      //else if ((x > 3 && x < 237) && (y > 114 && y < 158)) // logging
        //isLogging = !isLogging;
        //if (isLogging)
          //tft.fillRoundRect(3, 114, 234, 44, 4, 0x3B8F);
          //tft.drawRoundRect(3, 114, 234, 44, 4, WHITE);
          //tft.setCursor(38, 145);
         // tft.println("LOGGING ON");
        //else
         // tft.fillRoundRect(3, 114, 234, 44, 4, 0xB9C7);
          //tft.setCursor(33, 145);
          //tft.println("LOGGING OFF");
      //else if ((x > 3 && x < 237) && (y > 214 && y < 258))  // device mode
       // page = 8;
        //drawDeviceModePage();
    if (interval < 10)
      intervalSize = 1;
      intervalSize = 2;
      intervalSize = 3;
    tft.setFont();
    tft.setTextSize(3);
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
        page = 7;
        interval += 5;
          interval = 995;
        interval -= 5;
        if (interval <= 5)
          interval = 5;
        tft.setFont();
        tft.setTextSize(3);
        tft.println(cpm);
        if(cpm < 10)
        else if(cpm < 100)
        else if(cpm < 1000)
      if (completed == 0)
        drawCloseButton();
        completed = 1;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 0;
        drawHomePage();
        currentCount = 0;
        previousCount = 0;
          fastCount[b] = 0;
          slowCount[c] = 0;
    if (!ts.touched())
      wasTouched = 0;
      wasTouched = 1;
        page = 5;
//          EEPROM.commit();
        drawWifiPage();
        deviceMode = 0;
        deviceMode = 1;
void drawHomePage()
  tft.setTextSize(1);
  tft.setFont();
  tft.setTextSize(2);
  tft.println("+");
  tft.setTextSize(1);
  if (doseUnits == 0)
  tft.setTextSize(1);
  if (doseUnits == 0)
    tft.println("mR:");
  tft.setTextSize(1);
    tft.println("INT");
    tft.println("INT");
    tft.println("5 s");
    tft.println("INT");
  if (ledSwitch)
  if (buzzerSwitch)
  if (isLogging)
    tft.println("L");
  if (deviceMode)
  drawFrame();
  drawBackButton();
  drawFrame();
  drawBackButton();
  if (doseUnits == 0)
  if (doseUnits == 1)
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
void drawWifiPage()
  drawFrame();
  drawBackButton();
  if (isLogging)
  if (addr > 2000)
  drawFrame();
  drawBackButton();
  tft.setTextSize(3);
  tft.println("+");
  tft.println("-");
  tft.setTextSize(1);
  cpm = 0;
  progress = 0;
  drawFrame();
  drawCancelButton();
  tft.setTextSize(1);
  tft.println("min");
  currentCount = 0;
  completed = 0;
  drawFrame();
  drawBackButton();
    currentCount++;
    cumulativeCount++;
void drawFrame(){
  tft.setTextSize(1);
  tft.setFont();
  tft.setTextSize(2);
  tft.println("+");
  tft.setTextSize(1);
  if (isLogging)
    tft.println("L");
  if (deviceMode)
  tft.setTextSize(1);
    int deltaT = 600;
    char temp[10];
  tft.setTextSize(1);
void clearLogs()
    jsonBuffer[k] = 0;
  addr = 100;
//  EEPROM.commit();
  isLogging = 0;
Thanks!
Hello all, i made a simple and fast diagram in paint to explain how i plan to wire everything.
hope my weird diagram is clear to understand :slight_smile:
Thanks!
