ezza:
Re
la compil donne des erreurs, surement pas suite a ta modif Barbudor, mais plus a la structure du code, une fission ... heu ... fusion des deux codes ( suis nullos en C .... mais je creuse
bonjour
faut nettoyer le code (à l'eau lourde de preference ! 8) )
elapsedTime epsaledTime (dyslexie ?
manque un ;
une } en trop
ce code compile
Web Server et GEIGER
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
// Enter a MAC address and IP address.
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 33);
// (port 80 is default for HTTP):
EthernetServer server(80);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(3,4,5,6,7,8);
// Threshold values for the led bar
#define TH1 45
#define TH2 95
#define TH3 200
#define TH4 400
#define TH5 600
// Conversion factor - CPM to uSV/h
#define CONV_FACTOR 0.00812
// Variables
int ledArray [] = {10,11,12,13,9};
int geiger_input = 2;
long count = 0;
long countPerMinute = 0;
long timePrevious = 0;
long timePreviousMeassure = 0;
long time = 0;
long countPrevious = 0;
float radiationValue = 0.0;
// fin partie 1 geiger
pinMode(geiger_input, INPUT);
digitalWrite(geiger_input,HIGH);
for (int i=0;i<5;i++){
pinMode(ledArray[i],OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//partie geiger
//set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Radiation Sensor");
lcd.setCursor(0,1);
lcd.print("Board - Arduino");
lcd.clear();
lcd.print(" Test Cooking Hacks");
lcd.clear();
lcd.setCursor(0,1);
lcd.print("www.cooking-hacks.com");
delay(200);
lcd.scrollDisplayLeft();
lcd.clear();
lcd.print(" - Libelium -");
lcd.setCursor(0,1);
lcd.print("www.libelium.com");
lcd.clear();
lcd.print("CPM=");
lcd.setCursor(4,0);
lcd.print(6*count);
lcd.setCursor(0,1);
lcd.print(radiationValue);
attachInterrupt(0,countPulse,FALLING);
// fin partie geiger
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("compteur Geiger");
client.print(radiationValue);
client.println("
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
// partie geiger
// S'il s'est écouléplus de 10 secondes depuis la sernière mesure, il est temps d'en faire une nouvelle
if (millis()-timePreviousMeassure > 10000){
// calcul du temps écoulé en secondes
unsigned long elapsedTime = (millis() - timePreviousMeassure) / 1000;
// calcul du nombre d'impulsion par minute
countPerMinute = 60*count/elapsedTime;
// remise à zéro du compteur ici et surtout pas en fin de boucle;
count = 0;
// calcul de la radiation
radiationValue = countPerMinute * CONV_FACTOR;
// mise à jour du temps
// il est plus précis d'ajouter le tempsécoulé plutot que de relire millis(). cela permet de lisser des erreurs
timePreviousMeassure += 1000 * elapsedTime;
// supprimer le count = 0; en fin de if car on l'a fait plus haut
Serial.print("cpm = ");
Serial.print(countPerMinute,DEC);
Serial.print(" - ");
Serial.print("uSv/h = ");
Serial.println(radiationValue,4);
lcd.clear();
lcd.print("CPM=");
lcd.setCursor(4,0);
lcd.print(countPerMinute);
lcd.setCursor(0,1);
lcd.print(radiationValue,4);
lcd.setCursor(6,1);
lcd.print(" uSv/h");
//led var setting
if(countPerMinute <= TH1) ledVar(0);
if((countPerMinute <= TH2)&&(countPerMinute>TH1)) ledVar(1);
if((countPerMinute <= TH3)&&(countPerMinute>TH2)) ledVar(2);
if((countPerMinute <= TH4)&&(countPerMinute>TH3)) ledVar(3);
if((countPerMinute <= TH5)&&(countPerMinute>TH4)) ledVar(4);
if(countPerMinute>TH5) ledVar(5);
// count = 0;
void countPulse(){
detachInterrupt(0);
count++;
while(digitalRead(2)==0){
void ledVar(int value){
if (value > 0){
for(int i=0;i<=value;i++){
digitalWrite(ledArray[i],HIGH);
for(int i=5;i>value;i--){
digitalWrite(ledArray[i],LOW);
else {
for(int i=5;i>=0;i--){
