I received a SBM-20 GM tube a few days ago and decided to test it. I connected it to my Geiger counter prototype and set the voltage to about 400V. The anode resistor is 4,7Mohm and the cathode is connected to GND via 1.5K and 100K resistors (the middle point feeds a transistor and there is a 470pF capacitor across the resistors).
I have understood that a geiger tube conducts zero current while it's idle and it only causes a short pulse when some of the gas inside the tube is ionized. Is this correct?
However, my tube constantly conducts about 40uA of current, which results in the transistor being turned on continuously (Vbe=0.67V). This is not how it should work, right? >:(
Edit. I tried connecting only the anode to a variable voltage (via 4.7Mohm resistor) and measured the voltage at the anode using my multimeter (not sure about the impedance of the meter). There was no voltage at the anode until I reached about 250V. At 400V I measured 125V at the anode!
The meter shouldn't show any voltage at the anode except for the extremely short pulses, right?
