Hello i'm feeling stuck and hope I can find some ideas,
I am reading the value from Analog PIN A0 and I would like to create a tally/total everytime Analog pin A0 makes a reading of 10 or above. Something like:
/--analog count sketch 2015 --/
int analogPin = 0;
int val = 0;
int tcount = (not sure what goes here?)
Serial.begin(9600); // setup serial
val = analogRead(analogPin); // read the input pin
if val < 10 (tcount = val+1) /--stuck here as I don't know if this would record a running tally/total or how yikes!--/
SerialPrint ("total count:" tcount);
Should I be using '++' somewhere? As in to +1 to the count?
My brain is fizzing and confused now, so I thought i would reach out for help.
Many thanks in advance for advice and corrections. :o
You said to add to the tally when you get a reading of 10 or greater.
So I have set it up to trigger the counter when it is greater than 9.
int analogPin = 0; // set input pin
int val = 0;
int tcount = 0;
void setup(){
void loop(){
if (val > 9){
tcount++;
Serial.print("Total Count:");
Serial.println(tcount);
Ahh-haaaa! That helps a lot thanks. I guess I need to understand if statements better (and my < and > wink)
Just wondering also if it is possible to collect number of counts in a minute? Is it possible to do without using an RTC, or would it be better/more accurate to perform using an RTC module?
I can't really see a way to use millis() to collect counts in a minute.
Save the value of mllis() and the value of the count at the start of your minute then
unsigned long millisInMinute = 60UL * 60 * 1000;
if (millis() - startMillis >= millisInMinute) {
lastCount = newCount; // save the previous value
newCount = count;
startMillis += millisInMinute; // reset for next minute
Then the difference between lastCount and newCount will be number in a minute
All the variables associated with millis() should be unsigned long
To count the number of times the value goes above 10 per minute (or any time interval) only has meaning if you measure the value at a fixed time interval or also count the number of times you measured that value in a minute.
For example if your measuring a signal that is constantly above 10 for the entire minute at 1 sample per second the count would be 60 but if you measured the same signal every 10 milliseconds then the result would be 6000. Vastly different results and both meaningless unless you take into account the number of sample times as the true answer should be 1 (the value was constantly above 10 for the entire minute).
It also depends whether you want to refresh the rate every minute or not.
For example:
1st minute: 200 counts
2nd minute: 300 counts
You can either get it to display: Rate: 200 counts / minute : which is 200 counts divided by 1 minute Rate: 300 counts / minute : which is 300 counts divided by 1 minute
Each time the rate is refreshed.
Or the other alternative, you can get it to keep an overall tally. Rate: 200 counts/minute : which is 200 counts divided by 1 minute Rate: 250 counts/minute : which is 200+300 = 500 counts divided by 2 minutes
So it depends on how you want to record the data.
My last example was using the 2nd alternative
I have an old Geiger counter in a drawer that has no readout. It makes a 'click' everytime a particle of radioactive material touches the sensor/element.
I decided I could try to get a serial/LCD reading by connecting my Arduino nano to the 'click' speaker (positive to A0, & GND to GND). It seems to work reasonably well.
But I think the Arduino misses some clicks (perhaps 10-20%?) perhaps due to it's ability to run the sketch loop at a given speed, it seems to miss more 'clicks' as the code becomes more complex? I haven't investigated this possibility, but just observing so far over the last hour.
Here is a photo of the device connected to arduino just now:
here is the photo of the resulting serial monitor values using ScottC code:
here is the photo of the resulting serial monitor values using Benduino adaptation:
I think that was the fastest geiger-counter hack ever
For example: If the sensor reading goes from 0 to 20 in the first second, but then stays at a value of 20 for the rest of the minute. My previous code will produce the wrong result.
The following code should accommodate Riva's comment (I hope)
unsigned long previousMillis = 0;
int minutesElapsed = 0;
int val = 0;
int tcount = 0;
unsigned long tcountRate=0;
boolean isLow = false;
previousMillis = millis();
isLow = true;
if(val>9 && isLow){
tcount++;
isLow=false;
if(val<10){
isLow=true;
if((millis()-previousMillis)>60000){
minutesElapsed++;
previousMillis=millis();
tcountRate = (tcount / minutesElapsed);
Serial.print("Rate:");
Serial.print(tcountRate);
Serial.println(" counts / minute");
As you are trying to catch every click - you would be better off using Serial.print sparingly.
Maybe print every 10 seconds or every minute. This will reduce the number of missed readings.
The only way to get meaningful results would be to make the count loop very fast with little latency (no serial printing while counting) or a another method might be to process the speaker signal a bit to clean it up and adjust the level so you could use a digital interrupt to count with.
If you stick to the current method then the code will need tweaking so the value has to go high (above 10) and back low to count as 1 pulse else you could be counting a single high multiple times giving false counts.
Ok I will try reducing the serial.print time and examine this effect on the result.
The geiger sensor at rest is always zero(0), and I observed that when a 'click' is made the value is different each time; but always above ten(10), so I figure this is a good place to choose, maybe even just one(1) is satisfactory too.
I feel I must take a short break now to review, and stop my brain from fizzing. Now that 'counts-per-minute is obtained, there is no reason why microseiverts can't be calculated too using this blog post conversion:
"The standard unit of radiation dosing in an area is the micro-Sievert/hour (uSv/hr). For this tube, multiply its CPM by 0.0057 to get the equivalent uSv/hr radiation level."
Ok - now that I know what you are trying to do.
I would only update the display when you identify a click.
With the attempt to reduce the number of missed clicks.
