Hallo,
ich habe zwei von diesen Grove Bluetooth Modulen
http://www.seeedstudio.com/wiki/Grove_-_Serial_Bluetooth
Ich habe Sie am Arduino Mega (Pin 19 und Pin 18, spirch UART) und am Uno (Pin 6/7) angebunden.
Laut LED Status sind auch beide im Modus des “Paring”. Aber Sie verbinden sich nicht.
Ich nutze für den Master folgenden Code
BluetoothShield Demo Code Master.pde.This sketch could be used with
Slave.pde to establish connection between two Arduino.
2011 Copyright (c) Seeed Technology Inc. All right reserved.
Author: Steve Chang
This demo code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
For more details about the product please check http://www.seeedstudio.com/depot/
/* Upload this sketch into Seeeduino and press reset*/
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 19
#define TxD 18
String retSymb = "+RTINQ=";//start symble when there's any return
String slaveName = ";SeeedBTSlave";//Set the Slave name ,caution that ';'must be included
int nameIndex = 0;
int addrIndex = 0;
String recvBuf;
String slaveAddr;
String connectCmd = "\r\n+CONN=";
SoftwareSerial blueToothSerial(RxD,TxD);
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
//wait 1s and flush the serial buffer
Serial.flush();
blueToothSerial.flush();
char recvChar;
while(1){
if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
recvChar = blueToothSerial.read();
Serial.print(recvChar);
if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
recvChar = Serial.read();
blueToothSerial.print(recvChar);
void setupBlueToothConnection()
blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=1\r\n");//set the bluetooth work in master mode
blueToothSerial.print("\r\n+STNA=SeeedBTMaster\r\n");//set the bluetooth name as "SeeedBTMaster"
blueToothSerial.print("\r\n+STPIN=0000\r\n");//Set Master pincode"0000",it must be same as Slave pincode
blueToothSerial.print("\r\n+STAUTO=0\r\n");// Auto-connection is forbidden here
delay(2000); // This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n");//make the master inquire
Serial.println("Master is inquiring!");
//find the target slave
char recvChar;
while(1){
recvBuf += recvChar;
nameIndex = recvBuf.indexOf(slaveName);//get the position of slave name
//nameIndex -= 1;//decrease the ';' in front of the slave name, to get the position of the end of the slave address
if ( nameIndex != -1 ){
//Serial.print(recvBuf);
addrIndex = (recvBuf.indexOf(retSymb,(nameIndex - retSymb.length()- 18) ) + retSymb.length());//get the start position of slave address
slaveAddr = recvBuf.substring(addrIndex, nameIndex);//get the string of slave address
//form the full connection command
connectCmd += slaveAddr;
connectCmd += "\r\n";
int connectOK = 0;
Serial.print("Connecting to slave:");
Serial.print(slaveAddr);
Serial.println(slaveName);
//connecting the slave till they are connected
do{
blueToothSerial.print(connectCmd);//send connection command
recvBuf = "";
while(1){
if(recvBuf.indexOf("CONNECT:OK") != -1){
connectOK = 1;
Serial.println("Connected!");
blueToothSerial.print("Connected!");
}else if(recvBuf.indexOf("CONNECT:FAIL") != -1){
Serial.println("Connect again!");
}while(0 == connectOK);
Für den Slave nutze ich diesen Code
BluetoothShield Demo Code Slave.pde. This sketch could be used with
Master.pde to establish connection between two Arduino. It can also
be used for one slave bluetooth connected by the device(PC/Smart Phone)
with bluetooth function.
Author: Steve Chang
#define RxD 6
#define TxD 7
char recvChar;
while(1){
blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STPIN=0000\r\n");//Set SLAVE pincode"0000"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
Serial.println("The slave bluetooth is inquirable!");
Den Slave kann ich auch mit dem Handy suchen und verbinden. Allerdings wechselt auch dann die LED Anzeige nicht.
Habe ich evtl einen Pin Fehler?
Uno:
- Pin 6 Hardware = RX,
- Pin 7 Hareware = TX
Merga_
Pin 19 auf TX
Pin 18 auf RX
Ich habe im Code die Pins gedreht. Seit dem hat erzumindest den Zustand des Kopplungsversuches. Aber koppeln tut er nicht. Kann es an dem Umstand liegen, dass ich auf den UART Port ein Software Serial anwende?
