[gelöst] Wire.begin beeinflusst oneWire
Hallo,
ich sitze hier vor einem kleinem Problem mit OneWire und dem Wire.begin
lasse ich den Wire.begin Befehl weg funktioniert der OneWire und erkennt auch den Sensor.
#include <OneWire.h>
#include <Wire.h>
OneWire  ds(2);  // on pin 2 (a 4.7K resistor is necessary)
//  Wire.begin();          // enable I2C port.
  Serial.begin(9600);  // Start serial comunication at baud=115200
  Serial1.begin(115200); // Start serial comunication at baud=115200
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    ds.reset_search();
    delay(250);
    return;
    Serial.print("ROM =");
    for( i = 0; i < 8; i++) {
      Serial.write(' ');
      Serial.print(addr[i], HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
    Serial.println("CRC is not valid!");
    return;
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      type_s = 1;
    case 0x28:
      type_s = 0;
    case 0x22:
      type_s = 0;
    default:
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);        // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // "count remain" gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let's zero them
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    //// default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
  Serial.print("Temperature = ");
  Serial.print(celsius);
sobald ich aber Wire.begin einbinde Funktioniert OneWire nicht mehr, es werden keine Sensoren erkannt.
was muss ich anstellen um das Problem zu lösen?
Auf was für nem Board?
Auf einem Arduino Leonardo 32U4 Chip
Schade, bin ich raus ;( Nano (168/328), Uno, Mega geht. Sorry...
OK ich habe es gefunden.
Am Leonardo kann der I2C Bus auch an Pin2 und 3 genutzt werden. Da ich den oneWire auch auf Pim 2 hatte ging das aber nicht. Nun habe ich diesen auf Pin10 gelegt und es geht auch sofort.
Kannst Dir nen Lösungsklick geben :slight_smile:
I2C bzw SDA und SCL auf einem Arduino Board ist immer eine doppelte Herausführung von anderen Pins die als Digitale herausgeführt sind. Praktisch 2 Pins für den gleichen Anschluß mit verschiedener Beschriftung. Gleiches gilt fur SPI auf den 6Poligen ICSP-Stecker. Welches die Digitalen Pins nun sind, die diese Zweitfunktion haben (I2C oder SPI) ist entweder dem Datenblatt des Controllers oder der Beschreibung der I2C bzw SPI Schnittstelle auf der Arduino Referenz zu entnehmen.
zB: für I2C: Wire - Arduino Reference oder SPI - Arduino Reference
Grüße Uwe
Danke @uwefed. Das ist mir dann auch eingefallen, aber im Eifer des Gefechts völlig vergessen gehabt.
Hatte nur den Test meines selber entwickeltem Boards vor Augen und das wesentliche Ausgeblendet.
Aber nun Funktioniert ja alles wie es geplant war.
