General Help, with delay - or timed/wait before digitalwrite
Just want to add a delay that only waits to perform the digitalwrite...
Right now it works once, but then the solenoid will not turn off...
here is some video help...
Float is just a reed switch, maybe needs more resistance.
const int FLOAT_PIN = 8; // Pin connected to FLOAT switch (OPEN=FULL, CLOSED/CONTINUTITY = NEED WATER)
const int SOLENOID_PIN = A0; // SOLENOID pin - active-high
// Since the other end of the FLOAT switch is connected to ground, we need
// to pull-up the FLOAT switch pin internally.
pinMode(FLOAT_PIN, INPUT_PULLUP);
digitalWrite(SOLENOID_PIN, LOW);
pinMode(SOLENOID_PIN, OUTPUT);
digitalWrite(SOLENOID_PIN, LOW); //sanity check, water is normally off
if (digitalRead(FLOAT_PIN == LOW)) // if it needs water
delay(10000); // delay BEFORE filling.
while(digitalRead(FLOAT_PIN == LOW)){ // Fill till sensor says full, then exit. Water turned off at sanity check.
digitalWrite(SOLENOID_PIN, HIGH);
} //end while
} //end if
} //end loop
I've sent a personal message that you should read IMMEDIATELY. Look at your profile in the circle, upper right corner of this page.
A closing parenthesis is in the wrong place:
if (digitalRead(FLOAT_PIN) == LOW) // if it needs water
Same problem a few lines down:
... should be:
while(digitalRead(FLOAT_PIN) == LOW){
Also, switches like this should be debounced. Try the Bounce2 library.
I would also suggest looking at Using millis() for timing. A beginners guide, the Blink Without Delay technique and related examples in the General Design section of the Useful Links page.
That did the trick, thanks.
