general question on linear regulator
Hi guys,
I read somewhere that linear regulator can regulate output only if Vin is > vout. Is that true ?
Furthermore max efficiency is achieve when Vin is close to Vout. Does someone know how to evaluate efficiency and power dissipation? I plan to use max604 pdip package to regulate power for 328p chip is it a good idea ?
Bellow data sheet:
Thanks. BR
Yes.
The difference between input and output voltage multiplied by the current drawn is the power wasted in regulating. This is dissipated as heat.
It's OK, but limited to 500mA.
