general questions about arduino programming
I'm a beginner with arduino / arduino coding, got some stuff to play and learn with it, i'm stuck with something.
I wanna run code for a IR Remote to control a servo when i press the (+) button on the remote the servo start going to 180 degree but like one degree each press, like the volume thing on TV
i tried alot of thing with leds, servos from my background knowledge about simple stuff of programming and using some search help
i got almost everything work and fine i understand it
i came up with this
if (results.value == plus)
        angel = angel+1;
        Serial.println (angel);
what's in my mind is to make the angel write to the servo and everytime it get a +1
I decided to make it print so i see what's going on, when i call the function on loop it keep going to infinite if i pressed the button once
and including the func on setup don't recognize anything or run at all
Here's the full code including some led stuff i was trying :slight_smile:
#include <IRremote.h>
#include <Servo.h>
#define on 0xFF6897
#define off 0xFF30CF
#define plus 0xFF906F
Servo servo;
int ir = 11;
int led = 13;
int angel=0;
IRrecv irrecv(ir);
decode_results results;
  servo.attach(4);
  pinMode(led, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results))
     Serial.println(results.value, HEX);
     irrecv.resume();
    if (results.value == on)
      digitalWrite(led, HIGH);
    if (results.value == off)
      digitalWrite(led, LOW);
servo_1();
void servo_1()
        angel = angel+1;
As long as you don't receive a new IR message, results.value will remain the same, so your function will keep on incrementing the angle.
The solution: only call your servo_1 function if irrecv.decode returns true.
Pieter
PieterP:
Pieter
can u help me a little further, what will be the code for irrecv.decode returns true will look like?
You need to move your actions to inside the first if block
    irrecv.resume();
    // do ALL your actions here that needs to be done when you detect a IR button press
  // nothing here relating to the IR button press
