Hello everybody.
I have a project on DUE that work fine and I have to convert it on GIGA (M7) for use M7 with more powerfull and use M4 at secondary functions.
On DUE I produce 250 kHz signal by using timer4 with a library that i found. With that I could produce an interrupt from 48 nS to 3.1mS (320Hz to 21Mhz) with a fine step (48ns)
On GIGA with "Portenta_H7_TimerInterrupt.h", I can only produc a 100 kHz signal inperrupt with a 1µs step. I can't use it
Please do you known if existe a issue for me on GIGA ?
Part of code on DUE :
Created by Ivan Seidel Gomes, March, 2013.
Modified by Philipp Klaus, June 2013.
// TIMER_CLOCK1: MCK/2 = 42 MhZ, period 1 = 48 ns, period 0xffff = 3.1 ms, 320 Hz - 21.0 MHz
// TIMER_CLOCK2: MCK/8 = 10.5 MhZ,period 1 = 190 ns, period 0xffff = 12 ms, 80 Hz - 5.3 MHz
// TIMER_CLOCK3: MCK/32 = 2.6 MhZ, period 1 = 762 ns, period 0xffff = 50 ms, 20 Hz - 1.3 MHz
// TIMER_CLOCK4: MCK/128 = 656 khZ, period 1 = 3.0 us, period 0xffff = 200 ms, 5 Hz - 328 kHz
DueTimer& DueTimer::setFrequency(int frequency){
// Set the timer frequency (in Hz)
Timer t = Timers[timer]; // Get current timer configuration
uint32_t rc;
// BLOC 1 //
rc = VARIANT_MCK/2/frequency; // 2 --> TIMER_CLOCK1
//rc = VARIANT_MCK/8/frequency; // 8 --> TIMER_CLOCK2
//rc = VARIANT_MCK/32/frequency; // 32 --> TIMER_CLOCK3
//rc = VARIANT_MCK/128/frequency; // 128 --> TIMER_CLOCK4
pmc_set_writeprotect(false); // disable write protection
pmc_enable_periph_clk((uint32_t)t.irq); // Enable clock for the timer
// Set up the Timer PWM
// BLOC 2 //
TC_Configure(t.tc, t.channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK1);
//TC_Configure(t.tc, t.channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK2);
//TC_Configure(t.tc, t.channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK3);
//TC_Configure(t.tc, t.channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
TC_SetRC(t.tc, t.channel, rc); // Reset counter / fire interrupt
t.tc->TC_CHANNEL[t.channel].TC_IER=TC_IER_CPCS; // Enable the RC Compare Interrupt
t.tc->TC_CHANNEL[t.channel].TC_IDR=~TC_IER_CPCS; // disable all others.
return *this;
extern int FREQUENCE;
void TC4_Handler(void) {
uint32_t rc;
// BLOC 3 //
rc = VARIANT_MCK/ 2 /FREQUENCE; // CK1 48 ns, period 0xffff = 3.1 ms, 320 Hz - 21.0 MHz
//rc = VARIANT_MCK/ 8 /FREQUENCE; // CK2 190 ns, period 0xffff = 12 ms, 80 Hz - 5.3 MHz
//rc = VARIANT_MCK/ 32 /FREQUENCE; // CK3 762 ns, period 0xffff = 50 ms, 20 Hz - 1.3 MHz
//rc = VARIANT_MCK/ 128 /FREQUENCE; // CK4 3.0 us, period 0xffff = 200 ms, 5 Hz - 328 kHz
TC_SetRC(TC1,1, rc);
TC_GetStatus(TC1, 1);
DueTimer::callbacks[4]();
