I followed ladyada’s article, Sensor tutorials - IR remote receiver/decoder tutorial , to build an IR remote control with Arduino MEGA1280, the interval value between HIGH level and LOW level was changed to 6?s in accordance to MEGA1280. The codes worked properly when the carrier wave was below 1000 microseconds, but when I tried to generate about 9130?s carrier wave, the actual wave was about 816?s long, far below than the intervals (12?s/cycle * 352 cycles = 4224?s).
the debug info
carrier expected actual results
9130 352cycles and takes 816 ?s
850 33cycles and takes 856 ?s
560 22cycles and takes 572 ?s
7190 277cycles and takes 948 ?s
//code snippets
int IRledPin = 13; // LED connected to digital pin 13
int _38HZ_Space=6; //38KHz interval
long PowerOnArray[][2]=
1,913,0,412,1,85,0,22,1,87,0,23,1,87,0,25,1,85,0,25,1,85,0,26,1,85,0,
27,1,83,0,27,1,84,0,27,1,84,0,138,1,83,0,138,1,83,0,138,1,82,0,138,1,
82,0,139,1,82,0,140,1,80,0,32,1,75,0,144,1,76,0,146,1,74,0,38,1,69,0,
153,1,66,0,156,1,64,0,46,1,64,0,47,1,63,0,48,1,61,0,50,1,59,0,51,1,59,
0,163,1,56,0,55,1,56,0,55,1,55,0,166,1,56,0,165,1,56,0,166,1,55,0,165,
1,56,0,4021,1,719,0,209,1,56,0,0
pinMode(IRledPin, OUTPUT);
//Serial.println("Sending IR signal");
char Recv;
if (Serial.available()>0)
//Serial.println("Has incoming chars");
Recv=Serial.read();
Serial.println(Recv);
switch (Recv)
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
Serial.println("Power On...");
_38HZ_Space = Recv - 48;
Serial.println(_38HZ_Space);
PowerOn();
default:
void PowerOn()
long i,c;
long cmd,value;
c=sizeof(PowerOnArray)/sizeof(PowerOnArray[0][0]);
for (i=0; i<=c; i++)
cmd=PowerOnArray[0];
value=PowerOnArray[1];
if (cmd==1)
pulseIR(value*10,_38HZ_Space);
delayMicroseconds(value*10);
void pulseIR(long microsecs, long Interval) {
Serial.print(microsecs);
long i;
i= micros();
long c;
c=0;
cli();
while (microsecs > 0) {
digitalWrite(IRledPin, HIGH);
delayMicroseconds(Interval); // hang out for 6 microseconds
digitalWrite(IRledPin, LOW);
microsecs -= 26;
c++;
sei();
i = micros() -i;
Serial.print(" ");
Serial.print(c );
Serial.print("cycles and takes ");
Serial.print(i);
Serial.println(" us");
