limit = 8192, step = 486
Like I said
and limit is 4095. You read the datasheet, didn't you?
Yes, I read it several times. But you know I'm a neophyte and I didn't get the point immediately. U tell me to try those values and I wanted to show u the results. That's it
A value above 4095 is not accepted.
From the datasheet for MCP4821 - SPI interface with support for 20 MHz clock, fast setup time of 4.5 µs.
According to these data, even with a faster microcontroller you will hardly achieve 8 kHz at a full range of 4096 steps because the DAC itself is not fast enough.
Hi guys,
After a few die and retry, I finished by got a pretty smooth saw tooth wave with those values:
// high-res triangular wave
for (int i = 0; i < 512; i += 16)
// setOutput(0, GAIN_2, 1, i);
setOutput(i);
BUT ! I need to amplify the signal I think.
Thanks for all of ur responses.
Why didn't you just use discrete elements? Like transistors, timer 555 or Op Amp's.
