Generate digital clock of 1 MHz
Hello,
I am new in Arduino so I don't know if it is possible or not in Arduino.
I want to generate 4 phase lock square wave of 1 MHz which can be delayed by certain delays. Minimum delay resolution ideally should 1nS but if I can achieve a delay resolution of 10nS also, it would be nice.
I have Arduino nano (16 MHz), can nano do what I want? If yes, then how would it be possible?
A single clock cycle of a 16MHz Arduino is 16.25 nS. Does that tell you something?
...R
yea, I thought that as well. but still, want to confirm if there is any possibilities like overclocking or something.
Robin2:
...R
Yes, it tells me you can't do arithmetic.
62.5ns (note the lower case 's')
You're asking to overclock a 20 MHz processor (Arduino uses a 16 MHz crystal, but the processor itself is rated to run at up to 20 MHz), to 1 GHz. Seriously? That would also just be able to give you your desired 10 ns resolution. For a 1 ns delay resolution you'll have to look at a clock of at least 10 GHz - you need at least a handful of clock cycles to handle the delay.
GrooveFlotilla:
Grovelling apology :slight_smile:
...R
prabhak:
You can use the timer hardware in the Arduino to output a squarewave of 4MHz, you'd then need external logic to generate 4 phases.
You could make a crude variable delay with a couple of schmitt trigger inverters and an RC circuit using a digital potentiometer.
Yours,
TonyWilk
prabhak:
Hello,
Have you done any reasearch on the Arduino prior to asking your question?
Have you looked at the data sheet for the controller?
You need a much faster processor for something like this. you need to make changes at 10ns = ~100MHz, and you need to do math to figure out when to do that - meaning you need the processor to be significantly faster than that. This is far beyond what a typical micro can do, you may have a hard time finding an appropriate part for this.
DrAzzy:
Not true, you only need a much faster processor if the rate of change is in the MHz - unless you restrict yourself to direct synthesis from the processor pins.
Yours,
TonyWilk
You could just use the ds1307 real time clock.
it's simple:
  1. wire it up
    VCC >> 5v
    GND >> GND
    SCL >> SCL
    SDA >> SDA
    SQ >> output of 1MHz
  2. code it
here's the code:
// SQW/OUT pin mode using a DS1307 RTC connected via I2C.
// According to the data sheet (http://datasheets.maxim-ic.com/en/ds/DS1307.pdf), the
// DS1307's SQW/OUT pin can be set to low, high, 1Hz, 4.096kHz, 8.192kHz, or 32.768kHz.
// This sketch reads the state of the pin, then iterates through the possible values at
// 5 second intervals.
// NOTE:
// You must connect a pull up resistor (~10kohm) from the SQW pin up to VCC.  Without
// this pull up the wave output will not work!
#include <Wire.h>
#include "RTClib.h"
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
   #define Serial SerialUSB
#endif
RTC_DS1307 rtc;
int mode_index = 0;
Ds1307SqwPinMode modes[] = {OFF, ON, SquareWave1HZ, SquareWave4kHz, SquareWave8kHz, SquareWave32kHz};
void print_mode() {
  Ds1307SqwPinMode mode = rtc.readSqwPinMode();
  Serial.print("Sqw Pin Mode: ");
  switch(mode) {
  case OFF:             Serial.println("OFF");       break;
  case ON:              Serial.println("ON");        break;
  case SquareWave1HZ:   Serial.println("1Hz");       break;
  case SquareWave4kHz:  Serial.println("4.096kHz");  break;
  case SquareWave8kHz:  Serial.println("8.192kHz");  break;
  case SquareWave32kHz: Serial.println("32.768kHz"); break;
  default:              Serial.println("UNKNOWN");   break;
void setup () {
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  Serial.begin(57600);
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  print_mode();
void loop () {
  rtc.writeSqwPinMode(modes[2]);
  print_mode();
  //if (mode_index > 5) {
    mode_index = 2;
  while(1);
@ idesign, I don't see where the 1307 can output a square wave any faster than 32KHz. Can you explain?
Your code comes from here. They don't mention 1MHz there.
