Generate random bigNumber
Hi guys,
I’m using bigNumber library in order to implement a DH (diffie-hellman) exchange between arduino and iPhone.
Currently, the iPhone implementation is done.
I’m having troubles in generating a random bigNumber, since there’s no function in the library that does that.
I have to generate a random number which is smaller than a bigNumber p, with p very large (eg: 256bit number, or even more).
Could you give me any advice on how to achieve that?
Thanks in advance!
PS: Here’s the library of BigNumber I’m using: http://forum.arduino.cc/index.php?topic=85692.0
How about just concatenating the ascii representation of a random numbers of random numbers in a charBuffer and use the result to construct a BigNumber?
Thank you for the reply.
It's a good idea, but how do I manage to be sure that the random number is less than a given one (eg: p)?
Bye :slight_smile:
If less than p is all that is needed (I suppose p will be bigger than 10),
just generate 1 digit less than the ascii-representation of p has.
Whandall:
I would think also of this solution but it would exclude a (big) range of possible numbers.
so (think think think ....)
To get all numbers possible one should generate a random string that has the same length as the max number.
For every position one should check what range the digit may have.
an example with a smaller number
MAX = 65535
first digit may be 0..6
second digit may be 0..9 unless first is '6' then 0..5
third digit may be 0..9 unless first 2 digits is '65'
fourth digit may be 0..9 unless first 3 digits are '655'
fifth digit .... (ok you get it :wink:
wrote a small sketch to show how it can be done
//    FILE: randomCharArray.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.00
// PURPOSE: demo for bigNumber
//    DATE: 2015-10-24
//     URL: http://forum.arduino.cc/index.php?topic=355182
// Released to the public domain
char s[] = "123456789655357638576349875347563987659283476528374597357353734";
char r[100] = "";
uint32_t start;
uint32_t stop;
  Serial.print("Start ");
  Serial.println(__FILE__);
  randomSeed(analogRead(A0));
  start = micros();
  randomCharArray(s, r);
  stop = micros();
  Serial.print("LENGTH:\t");
  Serial.println(strlen(s));
  Serial.print("TIME:\t");
  Serial.println(stop - start);
  Serial.print("T/CHAR:\t");
  Serial.println(1.0 * (stop - start) / strlen(s));
  delay(2000);
  Serial.println(s);
  Serial.println(r);
int randomCharArray(char *s, char *r)
  bool critical = true;
  for (int i = 0; i < strlen(s); i++)
    int lm = s[i] - '0';
    if (critical)
      r[i] = random(lm + 1) + '0';
      critical = (r[i] == s[i]);
      r[i] = random(10) + '0';
  r[strlen(s)] = '\0';
The MAX string s starts with 123456789 to show that the generated random number will not exceed it.
generates 1 digit per 120 usec approx
traded speed for space
// VERSION: 0.1.01
//    DATE: 2015-10-24
char r[100] = "";
uint32_t start;
uint32_t stop;
  start = micros();
  stop = micros();
  delay(2000);
  Serial.println(s);
  Serial.println(r);
  byte i = 0;
  byte len = strlen(s);
  while (critical && i < len)
    byte lm = s[i] - '0';
    i++;
  while (i < len - 4)
    int rv = random(10000);
    byte t = rv / 1000;
    r[i++] = t + '0';
    rv -= t * 1000;
    t = rv / 100;
    r[i++] = t + '0';
    rv -= t * 100;
    r[i++] = rv / 10 + '0';
    r[i++] = rv % 10 + '0';
  while (i < len)
    r[i++] = random(10) + '0';
  r[len] = '\0';
int randomCharArray0100(char *s, char *r)
    if (critical)
Start randomCharArray.ino
LENGTH: 63
TIME: 2584
T/CHAR: 41.02
generates 1 digit per 41 usec approx
(size demo sketch = 5462 opposed to 5228 above)
Thank you robtillaart.
You're solution is very clever! You made my day!
I'll go with your solution :slight_smile:
Have a great day!
Squeezed some bytes and a few clock cycles.
// VERSION: 0.1.02
//    DATE: 2015-10-24
char r[100] = "";
uint32_t start;
uint32_t stop;
  start = micros();
  stop = micros();
  delay(2000);
  Serial.println(s);
  Serial.println(r);
  byte i = 0;
    i++;
  while (i < len - 4)
    rv /= 10;
    rv /= 10;
  while (i < len)
  r[len] = '\0';
LENGTH: 63
TIME: 2544
T/CHAR: 40.38
(size sketch = 5346)
For the bigNumber library you could make it more memory efficient as the result string (r) is not needed.
Just shift the digits directly into a bigNumber.
in pseudo code
BN = 0;
while (i< strlen(s))
BN * 10;
BN += generateNextDigit(s, i);
Played a bit with recursive generating big random number string,
in essence counting the # loops of this code
x = big;
while (x != 0) { x = random(x); count++ }
It has no use except as an statistical exercise as far as I can see
//    FILE: RandomBigNumberToZero.ino
// VERSION: 0.1.00
//    DATE: 2015-10-25
char s[] = "12345678965535763857634987534756398765928347652837459735735373723065723757632075437804943236344";
char r[100] = "";
uint32_t start;
uint32_t stop;
uint16_t  count = 0;
  start = micros();
  stop = micros();
  delay(2000);
  Serial.print(count++);
  Serial.print('\t');
  Serial.println(s);
  delay(200);
  Serial.print('\t');
  Serial.println(r);
  randomCharArray(r, s);
  delay(200);
  if (isZero(s)) while (1);
  byte i = 0;
    i++;
  while (i < len - 4)
    rv /= 10;
    rv /= 10;
  while (i < len)
  r[len] = '\0';
bool isZero(char *s)
    if (s[i] != '0') return false;
  return true;
// REFERENCE IMPLEMENTATION SMALL
    if (critical)
I refactored the code to perform much faster. Note there is a chance for starvation when no digit is generated. I can avoid that, but need some experiments to confirm.
// VERSION: 0.1.03
//    DATE: 2015-10-24
char r[100] = "";
uint32_t start;
uint32_t stop;
  start = micros();
  stop = micros();
  delay(2000);
  Serial.println(s);
  Serial.println(r);
// PERFORMANT IMPLEMENATION
  byte i = 0;
    i++;
  while (i < len)
    uint32_t rv = random();       // 4 bytes = 8 nybbles
    for (byte b = 0; b < 8; b++)
      byte v = rv & 0x0F;
      rv >>= 4;
      if (v > 9) continue;
      r[i++] = v + '0';
      if (i == len) break;
  r[len] = '\0';
    if (critical)
output:
LENGTH: 63
TIME: 1080
T/CHAR: 17.14
that’s 23 uSec off previous time (per digit) - see post #8
(sketch size 5,242 bytes)
A starvation patch in place,
// VERSION: 0.1.03
//    DATE: 2015-10-24
char r[100] = "";
uint32_t start;
uint32_t stop;
  start = micros();
  stop = micros();
  delay(2000);
  Serial.println(s);
  Serial.println(r);
  byte i = 0;
    i++;
  while (i < len)
    uint32_t rv = random();       // 4 bytes = 8 nybbles 0..15
    byte sum = 0;
      // get nybble
      byte v = rv & 0x0F;
      // prepare for next nybble
      rv >>= 4;
      // not in 0..9 ==> skip nybble but use its value.
      if (v > 9)
        sum += v;
        continue;
      r[i++] = v + '0';
    // if all nybbles are skipped, sum is at least 80
    // so we can use sum to generate at least one digit per iteration.
    if (i < len && sum >= 80)
      r[i++] = sum % 10 + '0';
  r[len] = '\0';
    if (critical)
Performance is ~0.5uSEc per char worse, so not to bad.
(sketch size 5,312)
To investigate/improve the evenly distribution of the additional digit.
