I want to use an Arduino Mega 2560 for an automotive application. It will be used to drive a seat motor in which the motor is connected to a chassis ground, and a +12V square wave regulates the speed of the motor. Here is the wave I need to produce.
Other specifications are as follows:
Load needs to support up to 10A
Needs to be able to switch on and off at high frequency, say 2-3KHz
Needs to have a logic-level control signal such that the Arduino GPIO is enough to turn it on
I've done a lot of research and it seems that the best solutions would be either a P-channel MOSFET, or an automotive-specific high side switch such as the BTS7002-1EPP from Infineon. I am somewhat deterred from using the latter because it seems like a lot of additional connections/components would be required. I'd like to keep the circuit as simple as possible.
I'm wondering if anyone has done something similar and what would be good components to use in this case. Any advice is appreciated. Thanks!
For an automotive application you may find a P channel mosfet a better choice especially if the device you are driving is grounded to the chassis (negative earth) . At 2kHz to 3kHz you may just find that a simple high side switch circuit with a strong pullup resistor is OK here without incurring high switching losses.
I did something similar and I used a bTS660, it is still working great. Be careful of your connections it will draw a lot of current if you have a fault. It is also important that it does not lose its ground connection.
