I'm pretty sure that Pin 9 and Pin 10 are completely in phase because they are both on Timer1. Setting one Output Compare Register 120 milliseconds after the other does nothing to change relative phase.
Since the phase difference is 0, what do you mean by "a phase between"?
johnwasser:
If they are in phase, then why do we say 'phase correct' and 'frequency correct' PWM signals?
A 100kHz square wave has a period of 10uS. You appear to be trying to put them 120mS "out of phase". Thing is, 120mS is exactly 12000 cycles of a 100kHz waveform so the two waveforms would technically be "in phase" anyway.
Can you draw an image of what you're trying to achieve or better describe it?
