Generating multiple frequencies using the MiniGen
I am new to Arduino and I am trying to use the signal generator shield MiniGen (SparkFun MiniGen - Pro Mini Signal Generator Shield - BOB-11420 - SparkFun Electronics, https://github.com/sparkfun/MiniGen) to output AC signal. I am trying to control the board with a switch, so that when it is flipped the MiniGen will output a low frequency for 10 seconds and then a high frequency for 10 seconds.
So far, this works:
#include <SparkFun_MiniGen.h>
#include <SPI.h>
MiniGen gen;
int switchState1 = 0;
  gen = MiniGen(10);
  gen.reset();
  delay(2000);
  gen.setMode(MiniGen::SINE);
  gen.setFreqAdjustMode(MiniGen::FULL);
  gen.selectPhaseReg(MiniGen::PHASE0);
  pinMode(9, OUTPUT);
  pinMode(2, INPUT);
    switchState1 = digitalRead(2);
    if (switchState1 == 1){
        static float frequency = 5.0;
        unsigned long freqReg = gen.freqCalc(frequency);
        gen.adjustFreq(MiniGen::FREQ0, freqReg);
However, this does not:
#include <SPI.h>
MiniGen gen;
unsigned long startMillis;
unsigned long currentMillis;
unsigned long previousMillis;
  gen = MiniGen(10);
  gen.reset();
  delay(2000);
  pinMode(9, OUTPUT);
  pinMode(2, INPUT);
  previousMillis = millis();
  currentMillis = millis();
  lowFreq();
  highFreq();
  Serial.println(currentMillis);
void lowFreq() {
  if (switchState1 == 1) {
    if (currentMillis - previousMillis < (10000)) {
void highFreq() {
    if (currentMillis - previousMillis < (20000)) {
      static float frequency = 15.0;
      previousMillis += 20000;
I’ve gone through the examples using millis(), but I am having trouble implementing it here. Any help or advice would be greatly appreciated.
What do your debug prints tell you is happening?
Why not?
