Generating PWM in sleep mode
Hello.
I wanted to generate PWM during a sleep mode. I have read on a one website, that it is possible while using timer2 in asynchronous mode.
I'm not quite sure what do I have to do. I would be glad if you could write step-by-step what I need to do or if you pasted the code with comments so I understood it.
Thank you for your help :)
Paweł
Read the datasheet,
10.6 Power-save Mode
If Timer/Counter2 is enabled, it will keep running during sleep.
and
10.9 Power Reduction Register
10.11.3 PRR – Power Reduction Register
You can find libraries to help with setting the right mode, or more than likely just write the registers directly.
