Genrating sbus signal through arduino UNO
Hi everyone I am trying to encode a sbus signal where the channel values are taken from few joysticks and switches states. The problem I facing now i have written the code and to verify if its a sbus signal I am interfacing this output TX pin(pin 1) of uno to my flight controller which is used in drones.
I am not able to see any movements in channel value. even when I set the frame to send 1300 pwm in all channels there is no data in mission planner.
// Pin Definitions
const int sbusPin = 1; // TX Pin for SBUS output (Use TX Pin 1)
// SBUS min and max values (for mapping to 11-bit SBUS values)
const int sbusMin = 172;   // Corresponds to ~1000 PWM (SBUS units)
const int sbusMax = 1815;  // Corresponds to ~2000 PWM (SBUS units)
// Function to send SBUS frame
void sendSBUSFrame(uint16_t channels[16]) {
  uint8_t sbusFrame[25] = {0};
  // Start byte
  sbusFrame[0] = 0x0F;
  // 11-bit encoding for each channel
  sbusFrame[1] = (channels[0] & 0x07FF);  // First 8 bits of Channel 1
  sbusFrame[2] = ((channels[0] >> 8) | (channels[1] << 3)) & 0xFF;  // Remaining bits of Channel 1 and first bits of Channel 2
  sbusFrame[3] = ((channels[1] >> 5) | (channels[2] << 6)) & 0xFF;  // Remaining bits of Channel 2 and first bits of Channel 3
  sbusFrame[4] = (channels[2] >> 2) & 0xFF;  // Remaining bits of Channel 3
  sbusFrame[5] = ((channels[2] >> 10) | (channels[3] << 1)) & 0xFF;
  sbusFrame[6] = ((channels[3] >> 7) | (channels[4] << 4)) & 0xFF;
  sbusFrame[7] = ((channels[4] >> 4) | (channels[5] << 7)) & 0xFF;
  sbusFrame[8] = (channels[5] >> 1) & 0xFF;
  sbusFrame[9] = ((channels[5] >> 9) | (channels[6] << 2)) & 0xFF;
  sbusFrame[10] = ((channels[6] >> 6) | (channels[7] << 5)) & 0xFF;
  sbusFrame[11] = (channels[7] >> 3) & 0xFF;
  sbusFrame[12] = (channels[8] & 0xFF);
  sbusFrame[13] = ((channels[8] >> 8) | (channels[9] << 3)) & 0xFF;
  sbusFrame[14] = ((channels[9] >> 5) | (channels[10] << 6)) & 0xFF;
  sbusFrame[15] = (channels[10] >> 2) & 0xFF;
  sbusFrame[16] = ((channels[10] >> 10) | (channels[11] << 1)) & 0xFF;
  sbusFrame[17] = ((channels[11] >> 7) | (channels[12] << 4)) & 0xFF;
  sbusFrame[18] = ((channels[12] >> 4) | (channels[13] << 7)) & 0xFF;
  sbusFrame[19] = (channels[13] >> 1) & 0xFF;
  sbusFrame[20] = ((channels[13] >> 9) | (channels[14] << 2)) & 0xFF;
  sbusFrame[21] = ((channels[14] >> 6) | (channels[15] << 5)) & 0xFF;
  sbusFrame[22] = (channels[15] >> 3) & 0xFF;
  // Flags byte (no failsafe or frame lost)
  sbusFrame[23] = 0x00;
  // End byte
  sbusFrame[24] = 0x00;
  // Send the SBUS frame
  Serial.write(sbusFrame, 25);
  // Initialize the serial port for SBUS output
  Serial.begin(100000, SERIAL_8E2);  // SBUS requires 100k baud, 8 data bits, even parity, 2 stop bits
  uint16_t channels[16];
  for (int i = 0; i < 16; i++) {
    channels[i] = 992;  // Corresponds to 1300 PWM (in SBUS units)
  sendSBUSFrame(channels);
  // Print debug information
  Serial.print("1: ");
  Serial.print(channels[0]);
  Serial.print(" 2: ");
  Serial.println(channels[1]);
  delay(14);  // Send SBUS frames every ~14ms (~72 Hz)
@prashantss
I'm not an sbus expert but I believe you need to invert the signal.
i have provision in my flight controller where there is a internal inverter so i tried with both inverted and non inverted params but the problem remains the same.
OK for inversion.
You are uoing the same serial port for sbus and printing debug info.
Will you flight controller ignore the debug data or will it cause it to malfunction?
ohh sorry I think this debug part I shouldn't have added it was one of the initial codes where I wanted to check but these lines I have deleted and checked just sending sbus frame through the serial port.
Even then the there was no data in mission planners radios window.
I have no futther suggestions other than to use one of the sbus libraries and/or use a logic analyzer to examine the data.
I wanted to use sbus libraries but all are for decoding the incoming message i couldn't find anything for encoding sbus frame.
But anyways thanks for your inputs.
Hopefully someone on the forum who has actually used an Uno to transmit sbus signals will see your topic.
