Genuine MEGA 2560 R3 Uploading problems (Intermittent)
Hi All
Like alot of other s i am having uploading issues. its not all the time but probably more than half. I have purchased several of the same boards but the issue still remains. when i put a new board on the port does change. I am using Windows 7 PRO Service Pack 1 64 bit. I requested verbose loading report and here it is
Arduino: 1.8.7 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 6660 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 292 bytes (3%) of dynamic memory, leaving 7900 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM17 -b115200 -D -Uflash:w:C:\Users\MIKETH~1\AppData\Local\Temp\arduino_build_276162/Winder20190102-01.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM17
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
An error occurred while uploading the sketch
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
option enabled in File -> Preferences.
As you can imagine this is frustrating during debugging (alot if uploading)and i would love some help find a solution.
(deleted)
Also ensure you have nothing else connected to the board at the time of upload.
Spycatcher thank you for your response, i will try it.
Bob, what do you mean nothing else hooked up to it? no Inputs / Outputs?
Yes nothing else attached to the board for I/O especially pins 0 & 1.
Bob, this happens several times a day, not the answer i was looking for lol. It also stops communicating via the serial output.
Are you logging the information itself at the computer end and if so what with ?
How much information are you passing the serial monitor / program per hour ?
Just in case its a buffer type issue.
What standby settings do you have enabled for power saving etc in your OS ?
Windows can shut down peripherals if it has any sort of power saving enabled so check ALL your power options.
What type of USB port are you using 1.0 / 2.0 / 3.0 ?
**I am using the serial monitor with the Arduino 1.8.7
**Its not really much this is one cycle of the test
Step: 0
Step: 10
Step: 20
Step: 30
Step: 40
Step: 50
Step: 60
Step: 70
Step: 80
Step: 90
Step: 100
Step: 110
Step: 120
Step: 130
Step: 140
Coil
And sometimes I can only run 1 or 2 tests then coms stop. I reset the board, that doesn't help, i have to unplug the USB for several minutes.
****I can run the test only seconds apart and one will work and one wont.
*****Based on age i would say 2.0
With it being intermittent I doubt it is your sketch but if you would like to post that using code tags ( </> ) it would certainly not harm.
It would also be helpful to know what you have connected to the board so a schematic would also be of use at this point.
