Genuino 101 battery pack
Is it possible to use an Li-ion 3.7v battery pack to power the Genuino 101 board?
I want to use it on a project for logging activites for mye dog during training.
It seems the board is rated for 3.3v power, so using a 3.7v-4.2v battery directly may cause some damage. Using a low-dropout voltage regulator may work, but is on the very edge of the regulators minimum input: http://www.ebay.com/itm/10Pcs-AMS1117-3-3-LM1117-3-3V-1A-SOT-223-Voltage-Regulator-/130750978645?hash=item1e715d9a55:g:raQAAOxyOeBR0T2C A better option would be a small buck converter, although they are usually rated for a minimum input of 4.5v, I have found they work very well with Li-ion batteries: http://www.ebay.com/itm/281665131443?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Hope this help. ~Josh
This board can not run on the 3.7 volt battery for a different reason. the pins are 3.3 to 5 volt tolerant. and the recommended input voltage is 7-12 volts.
