Genuino Uno Upload Problems
Just got my starter kit today and have been trying to upload the blink example
I have the uno selected for the board
And the board shows up in the ports and is selected
iv uninstalled the 1.6.10 ide and installed the 1.6.9 (drivers too just to be sure)
Any help would be appreciated I just keep getting the same error after a few minuets of trying to upload.
Error log :
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,066 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x72
Just did a loop back test and that worked fine :confused:
There have been several recent posts about Genuino UNO's having problems out of the box.
When you simply connect the board to USB, is the L led blinking on and off?
When you press the reset button does the L led blink rapidly several times?
Ah thanks it does appear to be the same problem
It blinks but pressing reset causes the led to stay on for a second then continue blinking slowly
