Genuino Zero Upload
I just bought n.2 Genuino Zero I updated the blink | Arduino 1.8.1 connected the programming port to COM8 got the following 'get board info' : BN: Arduino/Genuino Zero (Programming Port) VID: 03EB PID: 2157 SN: 00000000AZE000001702 set the Programmer "Atmel EDBG" if I try to burn bootloader I got the message "Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Uno"
Please select a programmer from Tools->Programmer menu
if I try to UPLOAD a Sketch I got the report :
C:\Users\GC\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8/bin/avrdude -CC:\Users\GC\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\GC\AppData\Local\Temp\arduino_build_560796/sketch_PMRua2016_rel06CxG0.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\GC\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8/etc/avrdude.conf"
Using Port : COM7 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4e avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4e
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Please HELP me, Thank You
today (apparently) I did some progress ... actually I got the ststus : Arduino: 1.6.9 (Windows 7), Board: "Arduino/Genuino Zero (Programming Port)"
... omissis ....
** Programming Finished ** ** Verify Started ** verified 24068 bytes in 2.028004s (11.590 KiB/s) ** Verified OK ** ** Resetting Target ** shutdown command invoked the selected serial port shutdown command invoked does not exist or your board is not connected
[SOLVED] ... it was a little bit exhausting but ... updated IDE as well as the Arduino SAMD library through the board manager and updated the USB driver on my Windows7 PC ... apparently the sketch upload succeed ... but didn't run ... launched the Burn Bootloader ... il works !
