Genuino101 - BLE disconnect event
101 is working as peripheral device (CurieBLE).
blePeripheral.setEventHandler(BLEConnected, bleConnectHandler);
blePeripheral.setEventHandler(BLEDisconnected, bleDisconnectHandler);
Only bleConnectHandler is triggered. When I turn off Bluetooth on Android device nothing happened.
void bleDisconnectHandler(BLECentral& central) {
  // central disconnected event handler
  Serial.print(F("Disconnected event, central: "));
  Serial.println(central.address());
What am I doing wrong?
Nobody can help me? :wink:
@hustler79 I'm not experience this issue on my Nexus 7 device use the "nRF Master Control Panel" app.
I'm using the CallbackLED.ino example sketch.
What app are you using? Which OS version are you using?
I have Motorola Moto G2 with Android 6.
I am using the same sketch as you but without any other app. It is a very simple sketch. Only two things: connect and disconnect event.
What I done:
I turned on only Bluetooth and I scanned if there are any (BL/BLE) devices. At this point it seems every thing is ok. But If I turn off Bluetooth nothing happened.
After that I have to restart Genuino.
Maybe it's a wrong way what I am trying to do.
I suggest you try it with an app, I suspect your phone is trying to pair with the Genuino, and this is not currently supported.
Try this nRF Master Control Panel
Ok, I will try.
I create my own app to scan for ble devices.
I think this could fix my problem :slight_smile:
Is there only one BLE lib which supports Genuino?
