hi guys…!!
I’m newbbie on arduino. Im using arduino
I have a GeoShield from liquidware and I trying to install this program in arduino
#include <Wire.h>
#include <LibCompass.h>
#include <SoftwareSerial_NB.h>
#include <LibGeoShield.h>
#include <HardwareSensor.h>
#include <stdarg.h>
#include <ctype.h>
#include <stdio.h>
#include <SoftwareSerial.h>
#include <Arduino.h>
#include <String.h>
- Definitions
#define GPS_RX_PIN 4
#define GPS_TX_PIN 5
#define GPS_BUFF_SIZE 528
#define G_SLOPE_5V 10.18
#define G_OFFSET_5V 3437
LibCompass compass = LibCompass(COMPASS_HW_GEOSHIELD);
SoftwareSerial gps = SoftwareSerial(GPS_RX_PIN, GPS_TX_PIN);
static char GPS_buff[GPS_BUFF_SIZE];
- Constructors
LibGeoShield::LibGeoShield(uint8_t GeoShieldType) {
gps.begin(9600);
_AccelGSlope = G_SLOPE_5V; //If different supply, please calibrate
_AccelGOffset = G_OFFSET_5V;
- Global Functions
- readGPS
- Used to read the entire GPS sensor output into a local buffer
@return char* - A pointer to the GPS data
char LibGeoShield::readGPS(void) {
char c;
GPS_buffIndex = 0;
memset(GPS_buff,0,GPS_BUFF_SIZE);
while (1) {
c = gps.read();
if (c == -1) {
GPS_buff[GPS_buffIndex] = (char)c;
GPS_buffIndex++;
return &GPS_buff[0]; //pass back a pointer to the entire buffer
- readCompass
- Reads the GeoShield’s on-board compass
@return int - The compass heading in degrees (0-360)
int LibGeoShield::readCompass(void) {
return (int)compass.GetHeading();
- setSupply
- Set the Arduino’s voltage supply. Used
- for accelerometer volts to mg’s conversion accuracy
- supplyVolts - The measured voltage of
- the AREF pin, for example, 4.97
void LibGeoShield::setSupply(float supplyVolts) {
_AccelGSlope = (supplyVolts / 5.00) * G_SLOPE_5V;
- readAccelX
- Reads the GeoShield’s on-board accelerometer
- @return int - The accelerometer position data
- in mg (thousands of a g)
int LibGeoShield::readAccelX(void) {
float val;
val = _AccelGSlope * analogRead(0) - _AccelGOffset;
return (int)val;
- readAccelY
int LibGeoShield::readAccelY(void) {
float val;
val = _AccelGSlope * analogRead(1) - _AccelGOffset;
return (int)val;
- readAccelZ
int LibGeoShield::readAccelZ(void) {
float val;
val = _AccelGSlope * analogRead(2) - _AccelGOffset;
return (int)val;
//Export the compass functions
bool LibGeoShield::CalibrateCompass(void) {
return compass.Calibrate();
void LibGeoShield::SleepCompass(void) {
compass.Sleep();
void LibGeoShield::WakeCompass(void) {
compass.Wake();
- ledOn
- The GeoShield has four onboard LEDs. Use this to
- control the GeoShield’s LED.
- ledNum - values are 0 - 3
void LibGeoShield::ledOn(uint8_t ledNum) {
if ((ledNum < 0) || (ledNum > 3)) {
return;
pinMode(ledNum+10, OUTPUT);
digitalWrite(ledNum+10, LOW);
- ledOff
void LibGeoShield::ledOff(uint8_t ledNum) {
return;
digitalWrite(ledNum+10, HIGH);
but I have this error
In file included from /usr/share/arduino/libraries/Wire/Wire.h:26:0,
from /usr/share/arduino/libraries/Wire/Wire.cpp:29:
/usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:86:3: error: ‘string’ does not name a type
string readString();
/usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:87:3: error: ‘string’ does not name a type
string readStringUntil(char terminator);
In file included from /usr/share/arduino/libraries/Wire/Wire.cpp:29:0:
/usr/share/arduino/libraries/Wire/Wire.h:60:20: error: conflicting return type specified for ‘virtual size_t TwoWire::write(uint8_t)’
virtual size_t write(uint8_t);
In file included from /usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:27:0,
from /usr/share/arduino/libraries/Wire/Wire.h:26,
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:38:18: error: overriding ‘virtual void Print::write(uint8_t)’
virtual void write(uint8_t) = 0;
/usr/share/arduino/libraries/Wire/Wire.h:61:20: error: conflicting return type specified for ‘virtual size_t TwoWire::write(const uint8_t*, size_t)’
virtual size_t write(const uint8_t , size_t);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:40:18: error: overriding ‘virtual void Print::write(const uint8_t, size_t)’
virtual void write(const uint8_t *buffer, size_t size);
/usr/share/arduino/libraries/Wire/Wire.cpp: In member function ‘virtual size_t TwoWire::write(uint8_t)’:
/usr/share/arduino/libraries/Wire/Wire.cpp:166:21: error: ‘setWriteError’ was not declared in this scope
setWriteError();
thx in advance.
