Gesture controlled car
Can we use the coding of nano to code pro mini means will nano's code will work as an alternative for nano for gesture controlled car
atharv1234:
I can't make sense of that.
Are you asking if a program that works on a nano will work unchanged on a pro-mini ? Is so, the simplest way to find out is to try it.
Why do you want to use a pro-mini rather than a nano?
Is the nano (or pro-mini) in the car, or is it part of the controller that sends commands to the car?
Posting you program is usually a good idea.
...R
