Gesture Controlled Trainable Arduino
Hello!
Im working on a school project and on that project im doing a Gesture Controlled Trainable Arduino Robot arm, i already have everything set to go, but one of the struggling parts for me is the code.
I really want to understand the code so i could explain it to my teacher, and i was wondering if anyone could help me out, if soo i would be greatfull.
if (realservo >= 1000 && realservo <1180){
int servo1 = realservo;
servo1 = map(servo1, 1000,1180,0,180);
pwm.setPWM(3, 0, pulseWidth(servo1));
Serial.println("Servo 1 ON");
delay(10);
I guess that PWM is used instead of the Servo library to control a servo. Depends on what pwm.setPWM() and pulseWidth() do.
If you post the COMPLETE code we will have a better chance of understanding what is going on. Just posting a tiny snippet so we have no idea what the variables are used for and what libraries and hardware are being used is a bit pointless.
I could guess that code is for a servo connected to a PCA9685 board. But they're is not common and never mentioned one.
Steve
At the same time, can you explain how the title of your thread has anything to do with your code?
Paul
Sure im sorry guys, here’s the full code, im working on a small project, that consists on doing a Gesture Controlled Trainable Arduino Robot Arm via Bluetooth with an app that remotely controls with gesture a robot arm.
Full code:
#include <AFMotor.h>
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define MIN_PULSE_WIDTH 650
#define MAX_PULSE_WIDTH 2350
#define DEFAULT_PULSE_WIDTH 1500
#define FREQUENCY 50
pwm.begin();
pwm.setPWMFreq(FREQUENCY);
//Read from bluetooth and write to usb serial
if(Serial.available()>= 2 )
unsigned int servopos = Serial.read();
unsigned int servopos1 = Serial.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println(realservo);
Serial.println("servo 1 ON");
delay(10);
if (realservo >=2000 && realservo <2180){
int servo2 = realservo;
servo2 = map(servo2,2000,2180,0,180);
pwm.setPWM(5, 0, pulseWidth(servo2));
Serial.println("servo 2 On");
delay(10);
if (realservo >=3000 && realservo < 3180){
int servo3 = realservo;
servo3 = map(servo3, 3000, 3180,0,180);
pwm.setPWM(8, 0, pulseWidth(servo3));
Serial.println("servo 3 On");
delay(10);
if (realservo >=4000 && realservo < 4180){
int servo4 = realservo;
servo4 = map(servo4, 4000, 4180,0,180);
pwm.setPWM(13, 0, pulseWidth(servo4));
Serial.println("servo 4 On");
delay(10);
if (realservo >=5000 && realservo < 5180){
int servo5 = realservo;
servo5 = map(servo5, 5000, 5180,0,180);
pwm.setPWM(11, 0, pulseWidth(servo5));
Serial.println("servo 5 On");
delay(10);
if (realservo >=6000 && realservo < 6180){
int servo6 = realservo;
servo6 = map(servo6, 6000, 6180,0,90);
pwm.setPWM(15, 0, pulseWidth(servo6));
Serial.println("servo 6 On");
delay(10);
int pulseWidth(int angle)
int pulse_wide, analog_value;
pulse_wide = map(angle, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
analog_value = int(float(pulse_wide) / 1000000 * FREQUENCY * 4096);
return analog_value;
Try looking up the language reference Arduino Reference - Arduino Reference for any statements you don't understand. Then if you have any specific questions about particular lines of code let us know.
Steve
