This may not be about arduino programing directly.
I'm developing a electronic system for Falcon BMS simulation with Arduino DUE. Swtiches and buttons working well with this system.
Now I want to get some data from game like if a system broken or not. Or like RPM information of engine. So if i can get these datas, i will send them by serial port.
How can i get these datas from game?
Can i do this with java on eclipse?
Thank you for you support.
As a start, you can use CheatEngine or similar, to find the memory addresses of the values that you are looking for. You can then write a program that will watch these values, and report changes to your arduino. It is not an easy task, especially if you have no idea about programming...
I have experiance with java. Are that memory asresses chanced when pc or game restarted? If it is, the algorithm that i will write is gonna find changed memory adresses every opening.
I can not trust chanced datas for every condition like 0 or 1. This change operation may be occupied so many time. I have to get data in a more trusted way.
Am i true?
