Get data from firebase to esp with arduino
i am trying to get data from my realtime database so i can send it to my esp. but i in the serial monitor i get the error 'data type mismatch' can anyone help?
#include <Arduino.h>
#if defined(ESP32)
  #include <WiFi.h>
#elif defined(ESP8266)
  #include <ESP8266WiFi.h>
#endif
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
// Insert your network credentials
#define WIFI_SSID "techniek"
#define WIFI_PASSWORD "test1234"
// Insert Firebase project API Key
#define API_KEY "API_KEY"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "DATABASE_URL"
//Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
float CO2;
bool signupOK = false;
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
    Serial.print(".");
    delay(300);
  Serial.print("Connected with IP: ");
  /* Assign the api key (required) */
  config.api_key = API_KEY;
  /* Assign the RTDB URL (required) */
  config.database_url = DATABASE_URL;
  /* Sign up */
  if (Firebase.signUp(&config, &auth, "", "")) {
    Serial.println("ok");
    signupOK = true;
  else {
    Serial.printf("%s\n", config.signer.signupError.message.c_str());
  /* Assign the callback function for the long running token generation task */
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
  if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 15000 || sendDataPrevMillis == 0)) {
    sendDataPrevMillis = millis();
    if (Firebase.RTDB.getFloat(&fbdo, "/test/float")) {
      if (fbdo.dataType() == "float") {
        CO2 = fbdo.floatData();
        Serial.println(CO2);
    else {
      Serial.println(fbdo.errorReason());
