You can use this code and configurations to get data from MPU 6050 or GY 521 or MPU 9250 with correct measurement units.
#include <Wire.h>
double accx, accy,accz, gyrox,gyroy,gyroz,temp;
const int Mpu=0x68;
Wire.begin();
Wire.setClock(400000); // I2C clock rate ,You can delete it but it helps the speed of I2C (default rate is 100000 Hz)
delay(100);
// turn Mpu on
Wire.beginTransmission(Mpu);
Wire.write(0x6B); // Power register
Wire.write(0); // wakes up the MPU-6050
Wire.endTransmission();
delay(100);
// Configure Gyro
Wire.write(0x1B); // Gyro Config
Wire.write(0x0); // (0: 250 dps (131 LSB/dps); 1: 500 dps (65.5 LSB/dps) ; 2: 1000 dps ( 32.8 LSB/dps) ; 3: 2000 dps (16.4 LSB/dps)
delay(100);
// Configure Accelerometer
Wire.write(0x1C); // Accelerometer Config
Wire.write(0x0); // (0: 2g (16384 LSB/g); 1: 4g (8192 LSB/g) ; 2: 8g ( 4096 LSB/g) ; 3: 16g (2048 LSB/g)
delay(100);
Serial.begin(115200); //Setting the baudrate
delay(100);
// Get data from MPU
Wire.write(0x3B);
Wire.requestFrom(Mpu,14);
accx=(int16_t)(Wire.read()<<8|Wire.read())/16384.00; // g
accy=(int16_t)(Wire.read()<<8|Wire.read())/16384.00; // g
accz=(int16_t)(Wire.read()<<8|Wire.read())/16384.00; // g
temp=(int16_t)(Wire.read()<<8|Wire.read())/340.00 + 36.53; // Celsus
gyrox=(int16_t)(Wire.read()<<8|Wire.read())/131.00; // Dps
gyroy=(int16_t)(Wire.read()<<8|Wire.read())/131.00; // Dps
gyroz=(int16_t)(Wire.read()<<8|Wire.read())/131.00; // Dps
Serial.print("accx= ");
Serial.print(accx);
Serial.print(" accy= ");
Serial.print(accy);
Serial.print(" accz= ");
Serial.println(accz);
if you want to get Euler Angles directly and exactly you can see this:
https://forum.arduino.cc/index.php?topic=563091.0
Also Here is my code to get Euler angles from GY-25 (MPU 6050 + Kalman filter) through Serial connection:
https://forum.arduino.cc/index.php?topic=588136.00
