Get data from multiple variables to a function
Hi Everyone,
I'm working with the Adafruit SAMD21 (M0) to get data from multiples sensors.
For Example the PressureSensor I get the data only by the function
SensorPressure spres; and afther that I get the data by an spres.getPressure();
I have a cpp file with the instructions for each sensor and a h
file with the variables.
The cpp File of Pressure Sensor,
//Initialize SensorPressure
SensorPressure::SensorPressure()
With the function SensorPressure spres; I have access to all the variables on the SensorPressure.cpp
However, If try to create a function SensorRain sRain; I show this error on Arduino IDE.
error: no matching function for call to 'SensorRain::SensorRain()'
58 | SensorRain sRain;
In file included from C:\Users\User\Documents\Arduino\File_Temp\File_Temp.ino:15:
C:\Users\User\Documents\Arduino\libraries\SensorRain/SensorRain.h:13:2: note: candidate: 'SensorRain::SensorRain(int)'
13 | SensorRain(int interrupt_pin);
Blockquote
I can not read the variables on the SensorRain.cpp Files.
Thanks for your help.
You have a strange view of the word "function",
you should look up its meaning in the C++ context again.
Your pressure sensor seems to be on I2C and has a default address,
so you can define such an object without any parameters/specification.
The rain sensor seems to need a pin to work on, which you did not specify.
SensorRain sRain(yourSensorPin); may work better, at least it will compile.
this part of the error message
tells you that the constructor for the rain sensor requires a parameter (likely a PIN number given the name) so if that pin is, say, pin 3 then your code needs to be like
#include "SensorRain.h"
const byte rainSensorPin = 3;
SensorRain sRain(rainSensorPin);
EDIT: need :eyeglasses:, exactly what @Whandall said....
Hello Whandall , J-M-L,
Thanks, Now is working the lecture of SensorPin.... :wink:
