The first project with Arduino101 I wanted to do was a pan/tilt head that would compensate the Arduino movement.
But to do that I needed the IMU returns the degrees of rotation that arduino101 has performed on each axis... I searched without finding anything similar on the internet especially without using external libraries (apart CurieImu).
This is the shortest code that I could do to get degrees from curieImu, I hope it can be helpful, feedback are much appreciated + feel free to use / fork this code!
* The code is released under the GNU General Public License.
* Developed by www.codekraft.it
#include "CurieImu.h"
// IMU
float FS_SEL = 131; // IMU gyro values to degrees/sec
unsigned long last_read_time;
float angle_x, angle_y, angle_z; // These are the result angles
float last_x_angle, last_y_angle, last_z_angle; // These are the filtered angles
float lGXA, lGYA, lGZA; // Store the gyro angles to compare drift
// FUNCTIONS
//Math
//Convert radians to degrees
double rtod(double fradians) {return(fradians * 180.0 / PI);}
void set_last_read_angle_data(unsigned long time, float x, float y, float z, float x_gyro, float y_gyro, float z_gyro) {
last_read_time = time;
last_x_angle = x; last_y_angle = y; last_z_angle = z;
lGXA = x_gyro; lGYA = y_gyro; lGZA = z_gyro;
while (!Serial);
// init CurieImu
CurieImu.initialize();
// use the code below to calibrate accel/gyro offset values
Serial.println("Internal sensor offsets BEFORE calibration...");
Serial.print(CurieImu.getXAccelOffset());
Serial.print("\t"); // -76
Serial.print(CurieImu.getYAccelOffset());
Serial.print("\t"); // -235
Serial.print(CurieImu.getZAccelOffset());
Serial.print("\t"); // 168
Serial.print(CurieImu.getXGyroOffset());
Serial.print("\t"); // 0
Serial.print(CurieImu.getYGyroOffset());
Serial.println(CurieImu.getZGyroOffset());
Serial.println("About to calibrate. Make sure your board is stable and upright");
// The board must be resting in a horizontal position for
// the following calibration procedure to work correctly!
Serial.print("Starting Gyroscope calibration...");
CurieImu.autoCalibrateGyroOffset();
Serial.println(" Done");
Serial.print("Starting Acceleration calibration...");
CurieImu.autoCalibrateXAccelOffset(0);
CurieImu.autoCalibrateYAccelOffset(0);
CurieImu.autoCalibrateZAccelOffset(1);
Serial.println("Enabling Gyroscope/Acceleration offset compensation");
CurieImu.setGyroOffsetEnabled(true);
CurieImu.setAccelOffsetEnabled(true);
set_last_read_angle_data(millis(), 0, 0, 0, 0, 0, 0);
unsigned long t_now = millis();
int ax = CurieImu.getAccelerationX();
int ay = CurieImu.getAccelerationY();
int az = CurieImu.getAccelerationZ();
int gx = CurieImu.getRotationX();
int gy = CurieImu.getRotationY();
int gz = CurieImu.getRotationZ();
// Convert gyro values to degrees/sec
float gyro_x = gx/FS_SEL;
float gyro_y = gy/FS_SEL;
float gyro_z = gz/FS_SEL;
// Compute the accel angles
float accelX = rtod(atan(ay / sqrt( pow(ax, 2) + pow(az, 2))));
float accelY = rtod(-1 * atan(ax/sqrt(pow(ay,2) + pow(az,2))));
// Compute the (filtered) gyro angles
float dt =(t_now - last_read_time)/1000.0;
float gyroX = gyro_x*dt + last_x_angle;
float gyroY = gyro_y*dt + last_y_angle;
float gyroZ = gyro_z*dt + last_z_angle;
// Compute the drifting gyro angles
float unfiltered_gyro_angle_x = gyro_x*dt + lGXA;
float unfiltered_gyro_angle_y = gyro_y*dt + lGYA;
float unfiltered_gyro_angle_z = gyro_z*dt + lGZA;
// Apply the complementary filter to figure out the change in angle
// Alpha depends on the sampling rate...
float alpha = 0.96;
angle_x = alpha*gyroX + (1.0 - alpha)*accelX;
angle_y = alpha*gyroY + (1.0 - alpha)*accelY;
angle_z = gyroZ; //Accelerometer doesn't give z-angle
// Update the saved data with the latest values
set_last_read_angle_data(t_now, angle_x, angle_y, angle_z, unfiltered_gyro_angle_x, unfiltered_gyro_angle_y, unfiltered_gyro_angle_z);
Serial.print("Y:" );
Serial.print(angle_y);
Serial.print(" \t Z:" );
Serial.print(angle_z);
Serial.print(" \t X:" );
Serial.println(angle_x);
