How can I get the gateway's (router's) IPv6 address with ESP32 STATtion?
Thank you.
Check the API, I imagine there is a function to do that.
Here is how to get it in old style, I have no idea how in V6
WiFi.gatewayIP();
Try this
// Print IPv6 addresses
if (WiFi.enableIpV6()) {
Serial.println("IPv6 enabled!");
// Local IPv6 address
Serial.print("Local IPv6: ");
Serial.println(WiFi.localIPv6());
// Gateway IPv6 address (not available directly in Arduino, but can be retrieved using custom libraries/tools if network supports it)
Serial.print("Gateway IPv6: ");
Serial.println("Check router or custom libraries for gateway info.");
Serial.println("Failed to enable IPv6.");
Thank you for answering. This works for IPv4 but not for IPv6. Lwip has a built-in option to do this but not all lwpi files are available in Arduino.
