Hello, first of all, i'm sorry if this is the wrong forum, and if i mispell something.
I need to get a string/json from this api: https://api.twitch.tv/kraken/streams/pedrinholuizf and check if 'streams' is null or not, how can I do it? Any external libraries that I can use? Exampel code would be great too.
Tanks
How is your arduino connecting with the internet? Please read the below:
http://forum.arduino.cc/index.php/topic,148850.0.html
I'm using an ethernet shield with an arduino Leonardo, but in the final project i will use an UNO board.
Client test code that captures what is sent from the server in the variable readString, which then can be evaluated for specific content.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
#include <Ethernet.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // myIP server test web page server
EthernetClient client;
void setup(){
 if (Ethernet.begin(mac) == 0) {
  Serial.println("Failed to configure Ethernet using DHCP");
  // no point in carrying on, so do nothing forevermore:
  while(true);
 Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
 Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
 // check for serial input
 if (Serial.available() > 0) //if something in serial buffer
  byte inChar; // sets inChar as a byte
  inChar = Serial.read(); //gets byte from buffer
  if(inChar == 'e') // checks to see byte is an e
   sendGET(); // call sendGET function below when byte is an e
 }Â
void sendGET() //client function to send/receive GET request data.
 if (client.connect(serverName, 80)) { //starts client connection, checks for connection
  Serial.println("connected");
  client.println("GET / HTTP/1.1"); //download text
  client.println("Host: checkip.dyndns.com");
  client.println("Connection: close"); //close 1.1 persistent connectionÂ
  client.println(); //end of get request
 else {
  Serial.println("connection failed"); //error message if no client connect
 while(client.connected() && !client.available()) delay(1); //waits for data
 while (client.connected() || client.available()) { //connected or data available
  char c = client.read(); //gets byte from ethernet buffer
  readString += c; //places captured byte in readString
 //Serial.println();
 client.stop(); //stop client
 Serial.println("client disconnected.");
 Serial.println("Data from server captured in readString:");
 Serial.print(readString); //prints readString to serial monitor
 Serial.println();Â
 Serial.println("End of readString");
 Serial.println("==================");
 readString=""; //clear readString variable
