I am working with A7672s with Esp32, At commands are working fine but getting location from gnss.
Testing code:
// #define TINY_GSM_MODEM_SIM7600 // SIM7600 AT instruction is compatible with A7670
#define SerialMon Serial
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_TEST_BATTERY true
#define TINY_GSM_TEST_GPS true
#define RXD2 27
#define TXD2 26
char a, b;
#define Power_pin 4
#define gsm_rst 25
#define TINY_GSM_MODEM_A7672X
float gps_latitude = 0;
float gps_longitude = 0;
float gps_speed = 0;
int8_t chargeState = -99;
int8_t chargePercent = -99;
int16_t milliVolts = -9999;
float lat,lon;
#include <TinyGsmClient.h>
// #include<SoftwareSerial.h>
// SoftwareSerial SerialAT(27, 26);
TinyGsm modem(Serial1);
const char apn[] = ""; //APN automatically detects for 4G SIM, NO NEED TO ENTER, KEEP IT BLANK
Serial1.begin(115200, SERIAL_8N1, RXD2, TXD2);
Serial.println("\nconfiguring the GSM Module. Kindly wait");
// pinMode(Power_pin,OUTPUT);
// digitalWrite(Power_pin, HIGH);
pinMode(gsm_rst,OUTPUT);
digitalWrite(gsm_rst,LOW);
digitalWrite(gsm_rst,HIGH);
DBG("Initializing modem...");
if (!modem.init()) {
DBG("Failed to restart modem, delaying 10s and retrying");
return;
String name = modem.getModemName();
DBG("Modem Name:", name);
String modemInfo = modem.getModemInfo();
DBG("Modem Info:", modemInfo);
Serial.println("Waiting for network...");
if (!modem.waitForNetwork()) {
Serial.println(" fail");
delay(5000);
Serial.println(" success");
if (modem.isNetworkConnected()) {
Serial.println("Network connected");
// GPRS connection parameters are usually set after network registration
Serial.print(F("Connecting to "));
Serial.print(apn);
if (!modem.gprsConnect(apn)) {
delay(5000);
return;
if (modem.isGprsConnected()) {
Serial.println("LTE module connected");
Serial.println("Enter Standard AT commands like AT, AT+CPIN?, AT+CCLK?, etc.");
Serial.println("SELECT SERIAL PORT MONITOR AS \"BOTH NL & CR\" TO VIEW COMMAND RESPONSE CORRECTLY IF YOU ARE USING ARDUINO IDE");
Serial.println("Refer A7600 series datasheet for entire list of commands");
Serial.println("Understand the AT Commands properly");
Serial.println("Incorrect AT commands can corrupt the 4G module memory!!!");
if (Serial.available() > 0) // read AT commands from user Serial port and send to the Module
a = Serial.read();
Serial1.write(a);
// Serial.print(modem.getGsmLocation());
if (Serial1.available() > 0) //read Response commands from module and send to user Serial Port
b = Serial1.read();
Serial.write(b);
Output:
AT+CGNSSTST=1
OK
AT+CGPSINFO
ERROR
AT+CGPSINFO=?
+CGPSINFO: (0-255)
OK
AT+CGPSINFO?
+CGPSINFO: 0
OK
AT+CGPSINFO
ERROR
