I have a php file in my website which returns sensor reading. I had been fetching this reading and displaying in my Serial monitor using the below code
http.begin("http://<MYWEBSITE>/fetch_sensor.php");
int httpCode = http.GET();
if (httpCode > 0) {
String payload = http.getString();
SensorReading = payload.toInt();
Serial.print("Sensor Reading=");
Serial.print(SensorReading);
Now I have updated my php file to return readings of multiple sensors. The readings are returned seperated by commas like 23,66,82,100
I am looking to update my code so that the readings returned by the php file is assigned as SensorReading1, SensorReading2, SensorReading3 etc.
Seeking help from experts..
Thanks!!
You did an internet search on the words "arduino parse comma delimited string" and did not get a result set? How strage.
I searched with the keywords you gave and got many results.. but really I can't figure out how to use it in my code
Here is some code I used to parse a comma delimited serial info.
void fParseLIDAR_ReceivedSerial ( void * parameters )
// distribute received LIDAR info
String sTmp = "";
sTmp.reserve ( 20 );
String sMessage = "";
sMessage.reserve ( StringBufferSize300 );
for ( ;; )
EventBits_t xbit = xEventGroupWaitBits (eg, evtParseLIDAR_ReceivedSerial, pdTRUE, pdTRUE, portMAX_DELAY) ;
xQueueReceive ( xQ_LIDAR_Display_INFO, &sMessage, QueueReceiveDelayTime );
// Serial.println ( sMessage );
int commaIndex = sMessage.indexOf(',');
sTmp.concat ( sMessage.substring(0, commaIndex) );
sMessage.remove( 0, (commaIndex + 1) ); // chop off begining of message
// Serial.println ( sTmp );
if ( sTmp == "!" )
xSemaphoreGive ( sema_LIDAR_OK );
// Display info from LIDAR
sLIDAR_Display_Info = sMessage;
if ( sTmp == "$" )
xEventGroupSetBits( eg1, evtResetWatchDogVariables );
if ( sTmp == "#")
// Serial.println ( "#" );
xSemaphoreTake( sema_LIDAR_Alarm, xSemaphoreTicksToWait );
sLIDAR_Alarm_info = sMessage;
xSemaphoreGive( sema_LIDAR_Alarm );
xEventGroupSetBits( eg, evtfLIDAR_Alarm );
// Serial.println ( "parse serial ok" );
sTmp = "";
sMessage = "";
xSemaphoreGive( sema_ParseLIDAR_ReceivedSerial );
// Serial.print( "fParseReceivedSerial " );
// Serial.print(uxTaskGetStackHighWaterMark( NULL ));
// Serial.println();
// Serial.flush();
vTaskDelete( NULL );
} // void fParseReceivedSerial ( void * parameters )
Good luck.
