GET request from multiple servers using one WiFly shield and WiFlyClients
HI,
I'm working with Arduino UNO and WiFly shield.
I'm trying to connect to several domains by the WiFly shield and make a GET request to them (one by one) in purpose to test these servers status (my GET request is to a specific page, on the server, which returns OK)
Do you know a way to make GET requests to different servers by one WiFly shield?
What I got until now is:
I can easily connect to one server by one WiFlyClient and make a GET request and get a good answer.
when trying to deal with two domains (two servers):
in setup() I got two WiFlyClients connection which succeeded to connect.
in loop() The first client is successfully reads the answer of get request and the second reads empty string.
-it doesn't matter who is the first and which is the second the second always fail to read or is unavailable.
-the schema requires that client.connect() call will be inside setup() function and client.read() call will be on loop() function any other schema fails to read or read jibrish.
  • I've got also Arduino MEGA if will be necessary, but it did not work with the WiFlyShield.
Thank you!
Einat.
