GET request with WifiNINA (mkr 1010)
i’ve been trying for a few days to get a basic GET request working but i keep receiving a 400 bad request
  Web client
 This sketch connects to a website (http://www.google.com)
 using the WiFi module.
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the Wifi.begin() call accordingly.
 Circuit:
 * Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and UNO WiFi Rev.2)
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 31 May 2012
 by Tom Igoe
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
char server[] = "kingstonsnows.webs.com";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET /");
    client.println("Host: kingstonsnows.webs.com");
    client.println("Connection: close");
    client.println();
    Serial.println(client);
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while (true);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
i’ve tried using different libraries and have gone through a bunch of forum posts but i can’t find a solution at this point i’m not really sure what todo.
The problem is that website only allows secure https connections. The sketch you are using is for websites that allow http connections. The appropriate example sketch to use for a reference in this case is File > Examples > WiFiNINA > WiFiSSLClient.
But first you need to load the root certificate for the site into the NINA WiFi module on your MKR 1010:
  • File > Examples > WiFiNINA > Tools > FirmwareUpdater
  • Sketch > Upload
  • Wait for the upload to finish.
  • Tools > WiFi101 / WiFiNINA Firmware Updater
  • Select the port of your MKR WiFi 1010 from the “Select port of the WiFi module” menu.
  • Click the “Add domain” button.
  • Enter “kingstonsnows.webs.com:443
  • Click the “OK” button.
  • Click the “Upload Certificates to WiFi Module” button.
  • Wait until you get the popup “The certificates have been uploaded”.
Now you can upload the modified WiFiSSLClient sketch to your MKR WiFi 1010:
This example creates a client object that connects and transfers
data using always SSL.
It is compatible with the methods normally related to plain
connections, like client.connect(host, port).
Written by Arturo Guadalupi
last revision November 2015
#include <SPI.h>
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
WiFiSSLClient client;
  while (!Serial) {
    // don't continue
    while (true);
  // attempt to connect to WiFi network:
    delay(10000);
  printWiFiStatus();
  if (client.connect(server, 443)) {
    client.println("GET / HTTP/1.1");
    client.println();
    Serial.write(c);
    client.stop();
    while (true);
void printWiFiStatus() {
  Serial.println(ip);
  Serial.print(rssi);
Thank you so much!
You're welcome. I'm glad if I was able to be of assistance. Enjoy! Per
Sorry, can you help please I'm facins the same issue, in my case, I need to access to my local machine:
http://localhost:49599/api/values
I've tried with:
char server[] = "localhost";
and
if (client.connect(server, 49599)) { Serial.println("connected to server"); // Make a HTTP request: client.println("GET /api/values HTTP/1.1"); client.println("Host: http://localhost:49599"); client.println("Connection: close"); client.println(); }
Thank you in advance
First, make sure the firewall of your server is not blocking the connection
