get return of bridge in javascript variable
Hello All,
I have searched this forum but didn't find any satisfactory help. Here is my question.
following the TemperatureWebPanel sample, I can read the return of my updated sensor value using :
$('#content').load('/arduino/temperature');
However, I don't want to put it in a HTML tag but in a javascript variable, for further processing.
I tried :
var temp; temp.load('/arduino/temperature');
but this doesn't work.
Can you help, please ?
Best regards
If you want just the temperature and none of the surrounding text, then you'll need to use a different server. OR rewrite the server to only return the temperature.
It might look like this:
if (command == "temperature") {
      int sensorValue = analogRead(A1);
      // convert the reading to millivolts:
      float voltage = sensorValue *  (5000/ 1024);
      // convert the millivolts to temperature celsius:
      float temperature = (voltage - 500)/10;
      client.print(temperature);
Jesse
