Hi.
I've been doing an obstacle avoidance robot.
It works fine.
It stops when obstacle is detected. turns. and goes again.
here's the code :
#include <NewPing.h>
#include <Servo.h>
Servo servoG;
Servo servoD;
Servo servoPan;
#define TRIGGER_PIN 12
#define ECHO_PIN 13
#define MAX_DISTANCE 400
const int dangerDist = 10;
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
int B = 0;
int A = 180;
void setup () {
Serial.begin (9600) ;
servoG.attach (9) ;
servoD.attach (10) ;
servoPan.attach (11);
servoPan.write (90);
delay (1000);
void loop () {
delay (500);
int uS = sonar.ping();
int dist = uS / US_ROUNDTRIP_CM ;
if (dist > dangerDist) {
go ();
else {
endgo ();
delay (500);
servoPan.write (140) ;
delay (500);
int uS140 = sonar.ping();
int dist140 = uS / US_ROUNDTRIP_CM ;
servoPan.write (40) ;
delay (500);
int uS40 = sonar.ping();
int dist40 = uS / US_ROUNDTRIP_CM ;
servoPan.write (120) ;
delay (500);
int uS120 = sonar.ping();
int dist120 = uS / US_ROUNDTRIP_CM ;
servoPan.write (60) ;
delay (500);
int uS60 = sonar.ping();
int dist60 = uS / US_ROUNDTRIP_CM ;
if ( uS60 + uS40 > uS120 + uS140 ) {
endgo();
backwards ();
endgo();
left ();
else {
endgo();
backwards ();
endgo();
right();
void go () {
servoG.write(A) ;
servoD.write (B) ;
void endgo () {
servoG.write (90) ;
servoD.write (90) ;
delay (500);
void backwards () {
servoG.write (B) ;
servoD.write (A) ;
delay (800);
void left () {
servoG.write (B) ;
servoD.write (B) ;
delay (500);
void right () {
servoG.write (A) ;
servoD.write (A) ;
delay (500);
I would like now to get rid of all delays so that I can do multiple tasks at the same time. and also - for my personnal understanding on how to to use millis () correctly instead of delays.
I tried this code which I thought would work. But I have absolutely not the same result.
The robot goes forward. hi head moves but it won't stop or turn.
What did I do wrong ? and how can I use just ONE easy : if (currenttimewheels - previoustimewheels > ...).
here's my new code :
#include <Servo.h>
Servo servoG;
Servo servoD;
Servo servoPan;
int B = 0;
int A = 180;
#define ECHO_PIN 13
unsigned long currrenttimewheels = 0;
unsigned long previoustimewheels = 0;
long waittimewheels = 5000;
void setup () {
servoG.attach (9) ;
delay (1000);
void loop () {
unsigned long currenttimewheels = millis ();
delay (500);
go ();
else {
endgo ();
delay (500);
delay (500);
delay (500);
delay (500);
endgo();
backwards ();
endgo();
left ();
else {
endgo();
backwards ();
endgo();
right();
previoustimewheels = currrenttimewheels;
void go () {
servoG.write(A) ;
servoD.write (B) ;
void endgo () {
if ( currrenttimewheels - previoustimewheels > waittimewheels) {
servoG.write (90) ;
servoD.write (90) ;
void backwards () {
servoG.write (B) ;
servoD.write (A) ;
void left () {
servoG.write (B) ;
servoD.write (B) ;
void right () {
servoG.write (A) ;
servoD.write (A) ;
and secondly , how could i have his head pan while the robot is still moving. as if I would like him to never stop turning his head . even if the robot is stopping. moving forward/backwards/left/right. ?
thanks a lot for your help
