get rid of the "A"
Hi All
Im trying to get rid of the A next to temp and cant see in the code where its saying to put the A in there in the first place.
See the screen shot for the display
#include <WiFi.h>
#include <WebServer.h>
#include "DHT.h"
// Uncomment one of the lines below for whatever DHT sensor type you're using!
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
/*Put your SSID & Password*/
const char* ssid = "Pattos Place";  // Enter SSID here
const char* password = "MVrocks2020";  //Enter Password here
WebServer server(80);
// DHT Sensor
uint8_t DHTPin = 4;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
  delay(100);
  pinMode(DHTPin, INPUT);
  dht.begin();
  Serial.println("Connecting to ");
  Serial.println(ssid);
  //connect to your local wi-fi network
  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network
  Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected..!");
  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  server.on("/", handle_OnConnect);
  server.onNotFound(handle_NotFound);
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
void handle_OnConnect() {
 Temperature = dht.readTemperature(); // Gets the values of the temperature
  Humidity = dht.readHumidity(); // Gets the values of the humidity
  server.send(200, "text/html", SendHTML(Temperature,Humidity));
void handle_NotFound(){
  server.send(404, "text/plain", "Not found");
String SendHTML(float Temperaturestat,float Humiditystat){
  String ptr = "<!DOCTYPE html> <html>\n";
  ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
  ptr +="<title>ESP32 Weather Report</title>\n";
  ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
  ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;}\n";
  ptr +="p {font-size: 24px;color: #444444;margin-bottom: 10px;}\n";
  ptr +="</style>\n";
  ptr +="</head>\n";
  ptr +="<body>\n";
  ptr +="<div id=\"webpage\">\n";
  ptr +="<h1>ESP32 Weather Report</h1>\n";
  ptr +="<p>Temperature: ";
  ptr +=(int)Temperaturestat;
  ptr +="°C</p>";
  ptr +="<p>Humidity: ";
  ptr +=(int)Humiditystat;
  ptr +="%</p>";
  ptr +="</div>\n";
  ptr +="</body>\n";
  ptr +="</html>\n";
  return ptr;
Not 100% sure but my ESP8266 weather station does not show that. Howevere there IS a difference.
My code has
ptr += "<body>\n";
  ptr += "<div id=\"webpage\">\n";
  ptr += "<h1>ESP8266 Weather Station</h1>\n";
  ptr += "<p>Temperature: ";
  ptr += temperature;
 [b] ptr += " &deg;C</p>";[/b]
  ptr += "<p>Humidity: ";
  ptr += humidity;
  ptr += " %</p>";
Yours has
ptr +="°C</p>";
So I reckon its just because ""° is not valid html. Change it to " °
That indeed looks like charset mismatch. I don't see anywhere in your code where this is set, so the browser is left guessing.
that worked perfectly John
Thank you
