Get sizeof individual array member
I need to get the length of each string within an array of strings.
Following code just returns 2 for each line.
Any suggestions?
#define NUMLINES 4
char *lines[NUMLINES] =
 "The way back\t",
 "Space Fall\t",
 "Cygnus Alpha\t",
 "Time Squad\t"
 Serial.begin(19200);
 for(int i = 0 ; i < NUMLINES; i++)
   Serial.print(lines[i]);
   Serial.println(sizeof(lines[i]));
void loop(void){}
Thanks
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” button above the posting area (It looks like a scroll with < > inside it).
Following code just returns 6 for each line.
Not on my Uno it doesn't:
The way back    2
Space Fall  2
Cygnus Alpha    2
Time Squad  2
Ok 2 then.
Point is its the same value.
Cheers
markl859:
Ok 2 then.
Cheers
Because… That is not an array of strings, it is an array of pointers to strings, and a pointer, in AVR, is two bytes.
Regards,
Ray L.
If you want the length of the strings, use strlen.
Thank you Nick,
Been a while since i used C.
You have saved my sanity.
Regards, Mark
