hi,
At my project I want to receive 4 byte from serial and then start to receive 12byte at the buffer
the bytes that I want to recognize are 02 00 03 00
at the serial port comes any byte but only if these bytes comes then start to receive the 12 bytes more at the BUFFER
then I wait to receive again 02 00 03 00 to start over
Use a 4 byte (circular or just shifting upon reception) buffer to keep getting the incoming bytes. Once the 4 bytes match 02 00 03 00 you know you got the header and can store the next 12 bytes in your payload.
I would suggest to study Serial Input Basics to get a good understanding on how to listen asynchronously to the Serial port.
here is a high level structure that would work, I let you write the code to handle the header
const uint8_t payloadLength = 12;
uint8_t payload[payloadLength];
bool getPayload(uint8_t pl[payloadLength]) {
enum tState : uint8_t {HEADER, PAYLOAD};
static tState state = HEADER;
const uint8_t startMarker[] = {0x02, 0x00, 0x03, 0x00};
const uint8_t startMarkerLength = sizeof startMarker;
static uint8_t marker[startMarkerLength] = {0xFF, 0xFF, 0xFF, 0xFF};
static uint8_t payloadPos = 0;
bool payloadComplete = false;
int r = Serial.read();
if (r == -1) return false;
switch (state) {
case HEADER:
=> shift marker[] array left to make space for the new byte at the end
=> insert (uint8_t) (r & 0xFF) at the end of marker array (marker[startMarkerLength - 1] )
=> compare the marker memory with startMarker on startMarkerLength bytes (use memcmp)
=> if match, reset the marker array for next time using memset, set payloadPos at the start of the buffer (payloadPos = 0;) and change the state (state = PAYLOAD;)
case PAYLOAD:
pl[payloadPos++] = (uint8_t) (r & 0xFF); // store the new byte
payloadComplete = (payloadPos >= payloadLength);
if (payloadComplete) state = HEADER;
return payloadComplete;
Serial.begin(115200); Serial.println();
Serial.println(F("I'm ready!"));
if (getPayload(payload)) {
Serial.print("Got payload : ");
for (uint8_t i = 0; i < payloadLength; i++) {
Serial.print(payload[i], HEX);
if (isalnum(payload[i])) {
Serial.write('(');
Serial.write((char) payload[i]);
Serial.write(')');
Serial.write(' ');
