hi hello there, am newbie here and got stuck with my program. Actually i use Nuvoton NUC140VE3CN in this case not the arduino, i just wanted ask about the program working even both of them use a same programming language.
So i trying to controlling some component like buzzer and led, before u can controll them u should be logged in with password. The problem is, when i has logged in the next program wont working.
heres the code:
char TEXT0[16] ="Controlling Component";
char TEXT1[16] ="KeyCode : ";
char TEXT2[16] =" ";
char passcode[7] ="123456";
char keycode[7] ="000000";
#define BLUE 1
#define GREEN 2
#define RED 3
void init_RGBLED(void)
// initialize GPIO pins
DrvGPIO_Open(E_GPA, 12, E_IO_OUTPUT); // GPA12 pin set to output mode
DrvGPIO_Open(E_GPA, 13, E_IO_OUTPUT); // GPA13 pin set to output mode
DrvGPIO_Open(E_GPA, 14, E_IO_OUTPUT); // GPA14 pin set to output mode
// set GPIO pins output Hi to disable LEDs
DrvGPIO_SetBit(E_GPA, 12); // GPA12 pin output Hi to turn off Blue LED
DrvGPIO_SetBit(E_GPA, 13); // GPA13 pin output Hi to turn off Green LED
DrvGPIO_SetBit(E_GPA, 14); // GPA14 pin output Hi to turn off Red LED
void RGBLED(uint8_t LEDcolor)
switch(LEDcolor) {
case BLUE: DrvGPIO_ClrBit(E_GPA,12); // Blue LED on
DrvGPIO_SetBit(E_GPA,13);
DrvGPIO_SetBit(E_GPA,14);
case GREEN: DrvGPIO_SetBit(E_GPA,12);
DrvGPIO_ClrBit(E_GPA,13); // Green LED on
case RED: DrvGPIO_SetBit(E_GPA,12);
DrvGPIO_ClrBit(E_GPA,14); // Red LED on
default: DrvGPIO_SetBit(E_GPA,12);
DrvSYS_Delay(100000 * LEDcolor);
// Function: input the number of buzz
void Buzz(int number)
int i;
for (i=0; i<number; i++) {
DrvGPIO_ClrBit(E_GPB,11); // GPB11 = 0 to turn on Buzzer
DrvSYS_Delay(100000); // Delay
DrvGPIO_SetBit(E_GPB,11); // GPB11 = 1 to turn off Buzzer
int main(void)
uint8_t i=0;
uint8_t number=0;
uint8_t number1=0;
init_RGBLED(); // initial RGB LEDs
UNLOCKREG(); // Unlock the protected registers
DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1); // Enable 12MHz oscillator
DrvSYS_Delay(5000); // delay for stable clock
DrvSYS_SelectHCLKSource(0); // HCLK clock source. 0: external 12MHz;
LOCKREG(); // Lock the protected registers
DrvGPIO_Open(E_GPA, 4, E_IO_INPUT); //set GPA0 to input mode
DrvGPIO_Open(E_GPB, 11, E_IO_OUTPUT); //initial GPIO pin GPB11 for controlling Buzzer
DrvGPIO_Open(E_GPB, 15, E_IO_INPUT);
Initial_pannel();
clr_all_pannal();
OpenKeyPad();
print_lcd(0, TEXT0);
print_lcd(1, TEXT1);
i=0;
while(1)
number=Scankey();
if (number!=0) {
DrvSYS_Delay(1000000);
keycode[i] = 0x30+number;
sprintf(TEXT1+9+i,"%d",number);
print_lcd(1,TEXT1);
i++;
//RGBLED(BLUE);
if(i==6){
if(strcmp(keycode,passcode)==0) {
RGBLED(GREEN);
sprintf(TEXT2,"PassCode:True");
print_lcd(2,TEXT2);
DrvSYS_Delay(250000);
clr_all_pannal();
print_lcd(0, "== Press Button ==");
print_lcd(1,"1. Turn On Buzzer");
print_lcd(2,"2. Green LED");
print_lcd(3,"3. Blue LED");
number1 =Scankey();
if (number1 !=0) {
if(number1==1) { Buzz(1);
} else if(number1==2) { RGBLED(GREEN);
} else if(number1==3) { RGBLED(BLUE);
RGBLED(RED);
Buzz(1);
printf(TEXT2,"PassCode: Wrong");
print_lcd(2,TEXT2);
