Get Text result
i'm using Arduino Leonardo and i have a question about its abilities.
i want to create some monitoring system.
i can ping google.com with below code when my computer windows7 command prompt is open and my leonardo is connected to my computer.
  Keyboard.print("ping google.com -t");
  Keyboard.press(KEY_RETURN);
  Keyboard.release(KEY_RETURN);
the result in command prompt is some thing like this:
C:\Users\programmer>ping google.com -t
Pinging google.com [173.194.116.104] with 32 bytes of data:
Reply from 173.194.116.104: bytes=32 time=405ms TTL=48.
Reply from 173.194.116.104: bytes=32 time=403ms TTL=48
Request timed out.
Request timed out.
I want to monitor ping result. How leonardo can understand that ping result has been changed to "Request timed out." ? is it possible only with programming ? does it needs to some extra hardware modules ?
Yes. The Leonardo will get a response via the Ethernet connection and you can parse the text to determine what it contains.
It can't. The output from the ping command is not routed to the Arduino.
Thanks Dear PaulS,
Does it impossible at all or i need to buy an Ethernet Module ?
we've just two Ethernet modules available in our country. W5100 and W5100 R3 - 2013. which is better for my work ?
Either W5100 will work. The R3 is probably a newer version, and a better choice.
The W5100 library comes with a Ping example.
