I'm using the push button with the built in pull-up resistor;
pinMode(b1, INPUT_PULLUP);
and have such a main loop. Whenever I press the push button and hold, the empty string called "pass" takes dozens of "1", as expected
However I want to make it sense the push once until I release it and push again.
By that structure, it is not likely to implement I think.
You must make a variable that holds the state of the button. Only if the state changes there is action
something like this
int pressed = 0;
 if (digitalRead(b1) == LOW && pressed == 0)
  pressed = 1;
  pass += "1";
  counter++;
 if (digitalRead(b1) == HIGH && pressed == 1)
  pressed = 0;
String pass;
int counter =0;
int pressed = 0;
int b1 = 3;
  pressed = 1;
  pass += "1";
  counter++;
  Serial.println(pass);
  pressed = 0;
Sample output of 4 button presses
1
11
111
1111
NOTE - no debounce implemented but the button action seems relatively snappy so not a problem
