Get thresholds of magnetic field data
Hello guys,
i am using a digilent 3axis digital compass to measure the magnetic field on a current wire to detect the state of a device. The signal turned out to be like wavy, so that i cant get thresholds easily (look at photo). In the beginning it can be seen that the device is off, and then it is turned on and then it is used(between 8000-10000). But how can i make a threshold analysis? like if the magnetic field is above 0 it is on and if its above 100 it is used otherwise its off. With this signal its difficult to be done because its compared to a sine wave.....
please help here is code and photo
#define DECLINATION 2.39 // declination (in degrees).
#include <Wire.h> //including library for I2C communication
unsigned char CMPS2_address = 0x30; //I2C address of the device
int taster=7;
int tasterstatus=0;
  Serial.begin(9600); //serial initialization
  delay(10);
  CMPS2_init(); //initialize the compass
  pinMode(taster, INPUT);
float data[3];
unsigned int raw[3];
float offset[3];
float current[3];
float field[3];
float rms;
int Cycles = 0;
  tasterstatus=digitalRead(taster);
  if (tasterstatus == LOW)
    Serial.println("Feldunterdrückung");
    for (int i=0;i<3;i++)
      field[i] = data[i];
    current[i] = data[i]-field[i];
  rms = sqrt(sq(current[0])+sq(current[1])+sq(current[2]));
  //delay(250);
  //retrieving and displaying the heading of the compass
  float angle = CMPS2_getHeading();
![mf|560x420](upload://AckiuJJECwALlMG9p9exW6Z3sPY.png)
  Serial.println(rms);
  //CMPS2_decodeHeading(angle);  //get direction
void CMPS2_decodeHeading(float angle) {
  //decoding heading angle according to datasheet
  if (angle > 337.25 | angle < 22.5) {
    Serial.println("North");
  else if (angle > 292.5) {
    Serial.println("North-West");
  else if (angle > 247.5) {
    Serial.println("West");
  else if (angle > 202.5) {
    Serial.println("South-West");
  else if (angle > 157.5) {
    Serial.println("South");
  else if (angle > 112.5) {
    Serial.println("South-East");
  else if (angle > 67.5) {
    Serial.println("East");
  else {
    Serial.println("North-East");
float CMPS2_getHeading(void) {
  CMPS2_read_XYZ();  //read X, Y, Z data of the magnetic field
  //eliminate offset before continuing
    data[i] = data[i]-offset[i];
  //variables for storing partial results
  float temp0 = 0;
  float temp1 = 0;
  //and for storing the final result
  float deg = 0;
  //calculate heading from data of the magnetic field
  //the formula is different in each quadrant
  if (data[0] < 0)
    if (data[1] > 0)
      //Quadrant 1
      temp0 = data[1];
      temp1 = -data[0];
      deg = 90 - atan(temp0 / temp1) * (180 / 3.14159);
      //Quadrant 2
      temp0 = -data[1];
      temp1 = -data[0];
      deg = 90 + atan(temp0 / temp1) * (180 / 3.14159);
  else {
    if (data[1] < 0)
      //Quadrant 3
      temp0 = -data[1];
      temp1 = data[0];
      deg = 270 - atan(temp0 / temp1) * (180 / 3.14159);
      //Quadrant 4
      temp0 = data[1];
      temp1 = data[0];
      deg = 270 + atan(temp0 / temp1) * (180 / 3.14159);
  //correct heading
  deg += DECLINATION;
  if (DECLINATION > 0)
    if (deg > 360) {
      deg -= 360;
    if (deg < 0) {
      deg += 360;
  return deg;
//reads measurements in mG
void CMPS2_read_XYZ(void) {
  //initialize array for data
  //command internal control register 0 bit 0 (measure)
  Wire.beginTransmission(CMPS2_address);
  Wire.write(0x07);
  Wire.write(0x01);
  Wire.endTransmission();
  delay(8);
  //wait for measurement to be completed
  bool flag = false;
  while (!flag) {
    //jump to status register
    Wire.write(0x06);
    //read its value
    Wire.requestFrom(CMPS2_address, (uint8_t)1);
    int temporal = 0;
    if (Wire.available()) {
      temporal = Wire.read();
    //if the last bit is 1, data is ready
    temporal &= 1;
    if (temporal != 0) {
      flag = true;
  //move address pointer to first address
  Wire.write(0x00);
  //save data
  Wire.requestFrom(CMPS2_address, (uint8_t)6);
  byte tmp[6] = {0, 0, 0, 0, 0, 0}; //array for raw data
    for (int i = 0; i < 6; i++) {
      tmp[i] = Wire.read(); //save it
  //reconstruct raw data
  raw[0] = tmp[1] << 8 | tmp[0]; //x
  raw[1] = tmp[3] << 8 | tmp[2]; //y
  raw[2] = tmp[5] << 8 | tmp[4]; //z
  //convert raw data to 1mG
  for (int i = 0; i < 3; i++) {
    data[i] = 0.48828125 * (float)raw[i];
//Update: this should follow Calibration steps
void CMPS2_init(void) {
  float out1[3];
  float out2[3];
  int i;
  Wire.begin(); // initialization of I2C bus
  //calibration: SET
  Wire.write(0x07);
  delay(10);
  Wire.write(0x80);
  delay(80);
  Wire.write(0x07);
  delay(10);
  Wire.write(0x20);
  delay(10);
  CMPS2_read_XYZ();
  for (i=0;i<3;i++)
    out1[i] = data[i];
  Serial.print("Raw SET = ");
  Serial.print(raw[0]);
  Serial.print("\t");
  Serial.print(raw[1]);
  Serial.print("\t");
  Serial.println(raw[2]);
  //calibration: RESET
  Wire.write(0x07);
  delay(10);
  Wire.write(0x80);
  delay(60);
  Wire.write(0x07);
  delay(10);
  Wire.write(0x40);
  delay(10);
  CMPS2_read_XYZ();
  for (i=0;i<3;i++)
    out2[i] = data[i];
  Serial.print("Raw RESET = ");
  Serial.print("\t");
  Serial.print("\t");
  //offset calculation
  for (i=0;i<3;i++)
    offset[i] = (out1[i]+out2[i])*0.5;
  //command internal control register 0 for set operation
  Wire.write(0x07);
  delay(10);
  Wire.write(0x40); //SET
  delay(10);
  //command internal control register 1 to 16 bit resolution, 8ms measurement time
  Wire.write(0x08);
  delay(10);
  Wire.write(0x00);
  delay(10);
mf
If You could post schematics it could help us.
I wonder if electronical noise around the circuits contributes to the trouble. I'm thinking about adding decoupling capacitors at every Vcc input of the circuits.
mf
it looks like this
You have posted that picture before. I asked You for schematics showing how the circuitry is done.
It simply looks like this
Still no schematics......
Long cables works as antennas picking up noise. As You are measuring electromagnetic fields I directly suspect that magnetic field might get inte those cables. I can think of using ferrits around the cables.
What does the actual measuring situation look like?
